JimC Posted November 12, 2009 Share Posted November 12, 2009 Guys, I wanted to star a thread to try and collect some info and get some more opinions. I have ahd a little discussion with Ibrar about this and his advice has been great as always, but i just wondered what other members are running.... Im looking for a slightly more aggresive whell offset on my supra as i feel the wheels could sit out another 10-15mm or there abouts. I am currently runnning 19" Vortex R (35mm offset) Tyres are 235,35,19 and 265,30,19 My question is what offset could i realistically run without having to chop the bodywork and to avoid any rubbing? Ibrar seems to think 30mm would be the limit but i wonder what people are actually running at the moment? If i am unable to gain much more without chopiing the arches etc, thats ok as i am in the process of lining up a guy to cut the arches back anyway, but i just thought it would be good to know the set up on other supras with 19" wheels. If a few people came back and said they are curtrently running 19" wheels with 20mm offset and no issues, i would be far more confident in heading down this road. I did manage to find this thread... http://www.mkivsupra.net/vbb/showthread.php?t=197901&page=2 but just wanted to try and collect some more info! Thanks guys Jim Quote Link to comment Share on other sites More sharing options...
JimC Posted November 13, 2009 Author Share Posted November 13, 2009 Bump Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 13, 2009 Share Posted November 13, 2009 Depends what width wheels you go with, a 9" front and 10" rear on a +35 is about the perfect offset imo, you can go lower with stretched tyres. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted November 13, 2009 Share Posted November 13, 2009 good thread. Subscribed. Quote Link to comment Share on other sites More sharing options...
steve spedd Posted November 13, 2009 Share Posted November 13, 2009 I tried the Vortex R 19's with 275 on the rear and they caught the arch big time. I had them rolled in the end. Don't know if that helps or not?? Quote Link to comment Share on other sites More sharing options...
merckx Posted November 13, 2009 Share Posted November 13, 2009 I tried the Vortex R 19's with 275 on the rear and they caught the arch big time. I had them rolled in the end. Don't know if that helps or not?? You need to specify the offset. I have 19's on the rear with 275 tyres with no rubbing at all, the offset being +37mm. Quote Link to comment Share on other sites More sharing options...
steve spedd Posted November 13, 2009 Share Posted November 13, 2009 First post mate.... he says the Vortex have an offest of 35mm Quote Link to comment Share on other sites More sharing options...
merckx Posted November 13, 2009 Share Posted November 13, 2009 First post mate.... he says the Vortex have an offest of 35mm Fair enough, but you didn't say yours were +35 aswell. The website I looked on lists the 19's as having an offset available from +20 to +45. Quote Link to comment Share on other sites More sharing options...
steve spedd Posted November 13, 2009 Share Posted November 13, 2009 Ah ok mate... Well i think thats what they sell for the supra. 265 are perfect. Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted November 13, 2009 Share Posted November 13, 2009 (edited) I would say that +30mm is just about the limit as per Ibrar's advice. I suspect you could go lower with height-adjustable suspension but a +25 (or lower) and you'll find the rubber starting to stick out from the arch big style Ibrar's calculation of a +50 offset, minus the 20mm gap between the vertical drop of the arch and the wheel, should give you the vertical play you need for 19's. Don't forget that the above figures are based upon a 9J size wheel as a 10J will generate an extra 12.5mm outward extension to the alloy wheel lip itself. Edited November 13, 2009 by SupraAyf Spelling (see edit history) Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted November 13, 2009 Share Posted November 13, 2009 People talking about offsets without taking into consideration wheel width is futile. Wheel width has an effect on what offset you can run. I did loads of research into this before buying my wheels. I found this tool to be most helpful http://www.morfed.net/wheel-offset-calculator/ Basically, put what offset and widths you have now, then put the new wheels dimensions in the lower part and it'll show you and tell you how much of a difference it'll be. Quote Link to comment Share on other sites More sharing options...
merckx Posted November 13, 2009 Share Posted November 13, 2009 People talking about offsets without taking into consideration wheel width is futile . It is. I couldn't be bothered to say what mine are , I've lost count of the number of times that I've done so. . Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 13, 2009 Share Posted November 13, 2009 It is. I couldn't be bothered to say what mine are , I've lost count of the number of times that I've done so. . Why bother posting then? without the wheel width the info is useless. Quote Link to comment Share on other sites More sharing options...
merckx Posted November 14, 2009 Share Posted November 14, 2009 (edited) Why bother posting then? without the wheel width the info is useless. If you look at my post and see who I was quoting you would see the point wouldn't you. Someone was saying they had rubbing issues with 275 tyres and 19" wheels, I was merely saying that I have the same setup with no rubbing at all. You don't have to be Einstein to realise that wheel widths matter. Edited November 14, 2009 by merckx (see edit history) Quote Link to comment Share on other sites More sharing options...
