dangerous brain Posted April 30, 2010 Share Posted April 30, 2010 Like said previously you may have an immobilizer that cuts out the ecu feed. You could do with getting that diagnosed first.If that fails to provide any insight perhaps you need to consider getting the car to a toyota dealership? Link to comment Share on other sites More sharing options...
Guest WOLFCHILD100 Posted May 1, 2010 Share Posted May 1, 2010 After replacing blown radio fuse, car ran fine then oil level, and brake lamp indicators flickered. Apex turbo timer was then acting up. Got to work but upon leaving, car stuttered, abs light began flickering and went solid and car died. Replaced 30a small efi fuse, disconnected tt, car started and ran....27 miles with ZERO electronics!? No guages, radio, lights, or power windows and seats,but trac, dome light and door gong worked. Found faulty ground on tt and fixed that in turn getting acc back. Still have the oil level and brake indicator fault lamps. And my factory alarm fob wont activate locks. Is any of this related or just coincedence? Fusible link maybe? Link to comment Share on other sites More sharing options...
