catfish man Posted November 11, 2009 Share Posted November 11, 2009 think i need a new thermosat as my engine is over heating? it stated blowing the heater pipes of? anyone else had this problem Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 11, 2009 Share Posted November 11, 2009 thers no oil an water mixing is ther , or blue smoke from the exhaust? Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted November 11, 2009 Share Posted November 11, 2009 or white smoke? Quote Link to comment Share on other sites More sharing options...
catfish man Posted November 11, 2009 Author Share Posted November 11, 2009 thers no oil an water mixing is ther , or blue smoke from the exhaust? no water mixed in with oil checked oil okay:) checked exhaust no smoke:) Quote Link to comment Share on other sites More sharing options...
steve spedd Posted November 11, 2009 Share Posted November 11, 2009 when you flushed the system how much coolant went back in mat? did you use Toyota 4life? Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted November 11, 2009 Share Posted November 11, 2009 my heater pipes also blow of but that was because the Oe clamp was bad , take the termostat of and boil it in water to check it, Quote Link to comment Share on other sites More sharing options...
stevie_b Posted November 11, 2009 Share Posted November 11, 2009 Blowing the heater pipes off? Crikey. I thought the radiator cap doubles up as a pressure safety valve that blows if the coolant pressure gets too much. Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted November 11, 2009 Share Posted November 11, 2009 Or your waterpump, if it is with palstic wheel it can go in 2 halfs and then there is no ciculation, did you push it when it happened? Quote Link to comment Share on other sites More sharing options...
catfish man Posted November 11, 2009 Author Share Posted November 11, 2009 my heater pipes also blow of but that was because the Oe clamp was bad , take the termostat of and boil it in water to check it,hi where is the thermosat:rolleyes: i dont know how to remove it:search: Quote Link to comment Share on other sites More sharing options...
catfish man Posted November 11, 2009 Author Share Posted November 11, 2009 Or your waterpump, if it is with palstic wheel it can go in 2 halfs and then there is no ciculation, did you push it when it happened? no did not push it tops 60mph:( Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 11, 2009 Share Posted November 11, 2009 Get the waterpump checked. Quote Link to comment Share on other sites More sharing options...
catfish man Posted November 11, 2009 Author Share Posted November 11, 2009 no did not push it tops 60mph:( put new clips on the pipes took the old ones of Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted November 11, 2009 Share Posted November 11, 2009 http://www.toyodiy.com/parts/p_J_1994_TOYOTA_SUPRA_JZA80-ALMVF_1603.html termostat http://www.toyodiy.com/parts/p_J_1994_TOYOTA_SUPRA_JZA80-ALMVF_1601.html waterpump Quote Link to comment Share on other sites More sharing options...
catfish man Posted November 11, 2009 Author Share Posted November 11, 2009 http://www.toyodiy.com/parts/p_J_1994_TOYOTA_SUPRA_JZA80-ALMVF_1603.html termostat http://www.toyodiy.com/parts/p_J_1994_TOYOTA_SUPRA_JZA80-ALMVF_1601.html waterpump cheers i thought it was there lost a days fishing but hopefully i should get sorted thankyou for your help:d Quote Link to comment Share on other sites More sharing options...
Scott Posted November 11, 2009 Share Posted November 11, 2009 Blowing the heater pipes off? Crikey. I thought the radiator cap doubles up as a pressure safety valve that blows if the coolant pressure gets too much. Surely that would point to a faulty rad cap as well? Quote Link to comment Share on other sites More sharing options...
catfish man Posted November 12, 2009 Author Share Posted November 12, 2009 Surely that would point to a faulty rad cap as well? would a faulty thermostate cause this problem to happen? if it was not working and stuck in 1 potison:rolleyes: Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 12, 2009 Share Posted November 12, 2009 would a faulty thermostate cause this problem to happen? if it was not working and stuck in 1 potison:rolleyes: If it was stuck closed, there would be no circulation, so overheating would occur, same as no water pump, however the rad cap should stop drastic overpressure, so i would also check that. Heater hose could just be down to a bad clip. Quote Link to comment Share on other sites More sharing options...
edge Posted November 12, 2009 Share Posted November 12, 2009 When its up to temp check the bottom rad hose. If thats hot then you have probably got circulation. Have you just done a coolant change? Did you bleed all the air out? Buy a new rad cap aswel. Quote Link to comment Share on other sites More sharing options...
AndyT Posted November 12, 2009 Share Posted November 12, 2009 Make sure it's an oem rad cap at 1.0 bar too. Higher pressure caps, 1.3 bar can cause failures too. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted November 12, 2009 Share Posted November 12, 2009 Just been thinking about the rad cap. The rad cap only blow if the rad sees too much pressure, and that probably won't happen unless the rad gets hot. The rad probably doesn't get hot until the thermostat opens up. If all of that is correct, then the rad cap might not be faulty after all. Does coolant flow around the heater matrix even if the 'stat is closed? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 12, 2009 Share Posted November 12, 2009 Just been thinking about the rad cap. The rad cap only blow if the rad sees too much pressure, and that probably won't happen unless the rad gets hot. The rad probably doesn't get hot until the thermostat opens up. If all of that is correct, then the rad cap might not be faulty after all. Does coolant flow around the heater matrix even if the 'stat is closed? The system will still pressurise in reverse and heat via convection, so the rad still sees pressure, even if the water in the rad is relatively cool. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted November 13, 2009 Share Posted November 13, 2009 Cheers for clearing that up Ricky. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 13, 2009 Share Posted November 13, 2009 If the coolant system got hot enough to pressurise so much, and so fast that the cap couldn't keep up with steam production, and it blew the heater pipes off I'd say you will have done some damage to the engine itself Overheating = stop, not slow down to 60 MPH Quote Link to comment Share on other sites More sharing options...
catfish man Posted November 13, 2009 Author Share Posted November 13, 2009 If the coolant system got hot enough to pressurise so much, and so fast that the cap couldn't keep up with steam production, and it blew the heater pipes off I'd say you will have done some damage to the engine itself Overheating = stop, not slow down to 60 MPH hi no i had stopped:) i noticed the problem at 60mph:( then pulled over no smoke or water in oil just fitted a new thermosat and its fine at the moment thankyou for everyones help Quote Link to comment Share on other sites More sharing options...
Terminator Posted November 13, 2009 Share Posted November 13, 2009 New head, but Chris beat me to it. Quote Link to comment Share on other sites More sharing options...
