scooby_doo_do Posted November 10, 2009 Share Posted November 10, 2009 (edited) I'm sure someone will be able to help with this :-) I've bought a winter project (celica Carlos sainz gt-4 1993), which is all good with the exception of the windows don't work. The previous owner has told me that he had trouble with the clifford alarm that was fitted - so he had it disconnected. (it's an old clifford alarm - no idea what model - how can i tell this?) I'm guessing this is why the windows don't work? Yesterday i had the dash off and found several boxes... http://www.tripkings.co.uk/gt4/large/0020.jpg The white block is a fuse block - with the fuses missing. I've checked this and there's definately power running through them. I also noticed a taped up power cable (to the left above big red fuses)... Shall i just stick some fuses in it and see what happens? Where do i connect the other taped up power cable too? Many thanks Craig. Edited November 10, 2009 by scooby_doo_do (see edit history) Quote Link to comment Share on other sites More sharing options...
madwoody1 Posted November 14, 2009 Share Posted November 14, 2009 go for the fuses being put in, i would say the other reason some cables (if its a pair or four) are disconnected is because it might be the immobiliser circuit to find out what the model is there will be an alarm box that should be up under the steering wheel and it will have the model type on if its a clifford Quote Link to comment Share on other sites More sharing options...
