random thought
w41k3r
jus had some wierd thoughts sat here doing nothing ....................
What would happen on an n\a if the manifold was custom made so that the 3 ports left went into 1 exhaust that run down one side of the car and the other 3 went into another exhaust down the other side or..........
What would happen if it wasnt 3 pipe design instead it was a triangle shape that bolted to the head to one pipe that went to the back of the car ? dodgey pic to follow
Edited by w41k3r (see edit history)
You cant do this as the fuel tank is in the way
:blink:
They are tuned resonance pipes, as such they follow a proper design. (Or at least they should)
There is a more indepth reason for this.
ok so if there tuned in that way couldnt they be tuned to do what i said ? also im sure ive seen supras with 2 exhausts either side before so if the fuel tanks in the way how do they do it?
No reason you couldn't route the pipes around, BUT it is a lot of fabrication work for no gain other than appearance. (And possibly some negative gains)
