ICE bits Headunit, Amp
The Raven
JCV KD-PDR61
Removed to fit a dvd player, with remote no box however.
I copied this from ebay
Product Features
· Power Output (50W x 4)
· MOS-FET Power Amp
· 24-Bit Burr-Brown DAC
· MP3/WMA Compatible
· CD-R/RW Compatible
· Multi-Colour Display ( 1728 colours )
· 3 Band Parametric iEQ
· 2.5V Line Output Level
· Line Output Terminals (2 x Pair)
· Detachable Face
· Front AUX input
· Front USB Input
· Built-in iPod controller (via front USB)
· CD Changer Control
· DAB Ready (optional KT-DB1000 tuner required)
Technical Details
CD Text
Direct Track Access (1-12)
Random/Repeat Play
+/-10 Key Function
HS-IV Tuner
IF Filter
6 AM and 18 FM Presets
SSM (for FM)
Seek (Up/Down)
AFNS/PNC
Stereo/Mono Switch (for FM)
RDS
MOS-FET Power Amp
Balance/Fader Control
Volume Attenuator
Dual Colour Control Illumination ( Green / Red )
Full DOT LCD-display
Dimmer
Main point is it has a usb port. Only down point one of the clips that holds the plastic surround is broken but that does not over affect the trim holding on.
These seem to go on ebay for £80-90 I will say £70+post
Amp.
SRS focus ct sounds,
4 channel amp. £30+ post
  • 2 weeks later...
