suprasonic Posted November 6, 2009 Share Posted November 6, 2009 found this posted on another site and thought it may make a few of you smile Im sure a few here have used the trusty haynes manual in the past and wondered "how the 'F' does this work, it says in the manual to do X-Y-Z but I cant even turn the bolt!!!!??" Indeed, every haynes car is spotlessly clean with no damaged/corroded bolts or threads and no optional extras that move or complicate the job even more. however, on another forum, I have found someone has kindly translated the haynes manual's secret code for us to use. Read and learn my friends! Haynes: Rotate anticlockwise. Translation: Clamp with molegrips then beat repeatedly with hammer anticlockwise. Haynes: This is a snug fit. Translation: Clamp with molegrips then beat repeatedly with hammer. Haynes: This is a tight fit. Translation: Clamp with molegrips then beat repeatedly with a hammer. Haynes: As described in Chapter 7... Translation: That'll teach you not to read through before you start. Now you are looking at scary photos of the inside of a gearbox. Haynes: Pry... Translation: Hammer a screwdriver into... Haynes: Undo... Translation: Go buy a tin of WD40 (giant economy size). Haynes: Retain tiny spring... Translation: PINGGGG - "Jesus, where the hell did that go?" Haynes: Press and rotate to remove bulb... Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part (and maybe a plaster or two). Haynes: Lightly... Translation: Start off lightly and build up till the veins on your forehead are throbbing then clamp with molegrips then beat repeatedly with hammer. Haynes:Weekly checks... Translation: If it isn't broken don't fix it. Haynes:Routine maintenance... Translation: If it isn't broken, it's about to be. We warned. Haynes:One spanner rating. Translation: An infant could do this... so how did you manage to **** it up? Haynes:Two spanner rating. Translation: Now you may think that you can do this because two is a low, teensy weensy number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you). Haynes:Three spanner rating. Translation: Make sure you won't need your motor bike for a couple of days. Haynes:Four spanner rating. Translation: You're not seriously considering this are you? Haynes:Five spanner rating. Translation: OK - but don't ever carry your loved ones in it again. Haynes:If not, you can fabricate your own special tool like this... Translation: Hahahahahahahahahahahahahahahahahahahahahahaha. Haynes:Compress... Translation: Squeeze with all your might, jump up and down on it, throw it at the garage wall, then find some molegrips and a hammer... Haynes:Inspect... Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one" Haynes:Carefully... Translation: You are about to suffer deep abrasions. Haynes:Retaining nut... Translation: Yes, that's it, that big spherical blob of rust. Haynes:Get an assistant... Translation: Prepare to humiliate yourself in front of someone you know. Haynes:Turning the engine will be easier with the spark plugs removed. Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs. Haynes:Refitting is the reverse sequence to removal. Translation: Yeah, right. But you swear in different places. Haynes:Prise away plastic locating pegs... Translation: Snap off... Haynes:Using a suitable drift... Translation: Clamp with molegrips then beat repeatedly with hammer. Haynes:Everyday toolkit Translation: RAC Card & Mobile Phone Haynes:Apply moderate heat... Translation: Unless you have a blast furnace, don't bother. Alternatively, clamp with molegrips then beat repeatedly with hammer. Haynes:Index Translation: List of all the things in the book, bar what you need to do. Link to comment Share on other sites More sharing options...
heckler Posted November 6, 2009 Share Posted November 6, 2009 http://www.mkivsupra.net/vbb/showthread.php?t=157553&highlight=haynes+manuals Link to comment Share on other sites More sharing options...
suprasonic Posted November 6, 2009 Author Share Posted November 6, 2009 sorry missed that did a search as well lol Link to comment Share on other sites More sharing options...
edge Posted November 6, 2009 Share Posted November 6, 2009 HAHAHAHA. Not seen that before! Very good. Link to comment Share on other sites More sharing options...
DODGYDODDS Posted November 6, 2009 Share Posted November 6, 2009 Link to comment Share on other sites More sharing options...
michael Posted November 6, 2009 Share Posted November 6, 2009 found this posted on another site and thought it may make a few of you smile Was the "other site" actually a cave full of dinosaurs or a pyramid that was still being built? So old that I think it was originally sent out by post because there wasn't an Internet. Link to comment Share on other sites More sharing options...
Abz Posted November 6, 2009 Share Posted November 6, 2009 http://i113.photobucket.com/albums/n206/DODGYDODDS/family_circus_repost.jpg Love it! Link to comment Share on other sites More sharing options...
JS2004 Posted November 7, 2009 Share Posted November 7, 2009 Repost or not, that was funny I dont think id of stumbled on the old one Link to comment Share on other sites More sharing options...
Professor Kenny Posted November 7, 2009 Share Posted November 7, 2009 http://www.b3tards.com/u/a7133557b6e7694b02de/haynes_redt.jpg http://www.b3tards.com/u/a7133557b6e7694b02de/haynes_bluet.jpg http://www.b3tards.com/u/a7133557b6e7694b02de/haynes_blackt.jpg Link to comment Share on other sites More sharing options...
