mikerunner Posted November 10, 2009 Author Share Posted November 10, 2009 so the szr 6 speed is a gold piston are the other two red (na and tt) or one of them gold, my next step then is to try get hold of szr slave seen as this solved dudes problem. do you think toyota will stock piston seperatly or would i have to get hole new slave Link to comment Share on other sites More sharing options...
SteveR Posted November 10, 2009 Share Posted November 10, 2009 Nice knowledge Chris! Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 10, 2009 Share Posted November 10, 2009 You need the whole thing, as the different pistons fit different bodies. SZR 1994 5speed; 04313-17010 (repair kit) 31470-22120 (complete slave cylinder) 31473-22010 (push-rod) SZ 1994 5speed; 2 types; 04313-17010 04313-22030 (repair kit) 31470-22120 (complete slave cylinder) 31473-20031 (2nd repair kit) 31473-22010 (push-rod) GZ 1994 6speed; 04313-14020 (repair kit) 31470-14060 (complete slave cylinder) 31473-14030 (push-rod) RZ 1994 6speed; same as GZ Link to comment Share on other sites More sharing options...
mikerunner Posted December 3, 2009 Author Share Posted December 3, 2009 finally got the car back from garage i had to wait 3 weeks to get a complete slave from toyota, i tried a repair kit but didnt work, had to replace my slave for smaller poston slave, with this new set up my bitting point is at the very bottom even with the smaller piston, only just releases, im guess it may take a few miles to wear in, and bitting point might come up abit, Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 3, 2009 Share Posted December 3, 2009 They tend to do the opposite when they bed down..... Link to comment Share on other sites More sharing options...
mikerunner Posted December 3, 2009 Author Share Posted December 3, 2009 with the smaller slave you get more travel right? i would have thought the smaller slave would have made bitting point alot higher, so with the longer slave i get less travel and no release of clutch, i struggle alit understanding the relation with slave size and peddle. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 3, 2009 Share Posted December 3, 2009 (edited) A smaller diameter slave piston will extend further per inch of master cylinder travel. A larger slave piston will extend less. So the smaller slave piston should have moved the arm and bearing further, (quite a bit further given the diameters of the two slave pistons), with the clutch pedal pressed to the floor, and hence the clutch should have released with less pedal movement. . I suspect something else is wrong here. Edited December 3, 2009 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
mikerunner Posted December 3, 2009 Author Share Posted December 3, 2009 with clutch to the floor i can change gear and it doesnt creep, if i raise 5mm its at bitting point, thats with smaller slave fitted, do you think its a fitting issue or something else wrong like master cylinder i also noticed in the inspection panel for clutch that the release arm/folk was wobble slightly loose, should that be the case? Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 3, 2009 Share Posted December 3, 2009 It could be the master cylinder, for sure. It could also be the clutch itself. The arms do wobble a bit as they are, to a certain extent, self aligning. Link to comment Share on other sites More sharing options...
dude Posted December 4, 2009 Share Posted December 4, 2009 Mike I thought this was all sorted as i hadn't heard from you!!!! Rob did as I said and gave the car an absolute thrashing and the pedal is now great, he loves it, try doing just that a big rpm launch and slip the clutch a lot then really give it some stick. Link to comment Share on other sites More sharing options...
dude Posted December 4, 2009 Share Posted December 4, 2009 Just seen your other post dude, I take it the same garage fitted the clutch!!!!! If you are stuck and worried bring the car down and I'll have a look at it and see if we can sort it for you (FOC of course) If you decide to go for a rebuilt master let me know I can get a kit and rebuild mine then we can just fit it straight to yours, so no hanging about, Im going to fit a kit to mine anyway. Link to comment Share on other sites More sharing options...
mikerunner Posted December 6, 2009 Author Share Posted December 6, 2009 dude your a legend, yeah was same garage, was waiting for slave from toyota, will phone ya monday morning. Link to comment Share on other sites More sharing options...
JODY T Posted August 6, 2010 Share Posted August 6, 2010 Just read this and not sure if i will need another slave cylinder.. I have a v161 in a SZR 6speed? I had assumed the slaves were the same.. I wanted this fitted for supra pod, but not sure i want to dismantle car only to find im stuck in gear.. Any help would be great Link to comment Share on other sites More sharing options...
