Mikes Project (miko_supra)
miko_supra
  • Replies 217
Looking forwards to seeing the dyno..! Awesome project..!
Do you think that the SB Stage 2 clutch will suffice for your power goals..? Did you consider the stage 3? How did you get the V160 out to change the clutch at the end? Did you use toyota's v160 oil?
All the best with the rest of your build looking forwards to seeing the final result..!
Ps. Sorry for the million questions mate just curious..! lol
Well they've stated that it holds over 600 lb.ft of torque which is plenty! Gearbox comes out like any other box, just remove the prop, gear linkage, bell housing bolts then whip the thing out. I used some silkoline gear oil.
I asked how you got the gearbox out because earlier on the thread you were having problems getting to it and out from under the car using only axle stands..! I am fixing to do mine soon with SB too just trying to soak up as much knowledge as possible.
I wondered about he stage 2 as the most popular one is the stage 3 on single builds.
cheers mate.
Edited by Brazil (see edit history)
cheers mate.
I just left the gearbox under the car whilst I changed the clutch.:)
  • 1 month later...
