Yet another PC problem question
CJ
Well that wasn't very successful. :(
I got into the set up screen and had a list that included "advanced bios features" but the sub menu didn't show anything like "halt on".
I then checked the other menus and sub menus and it doesn't appear there either. :(
Least you got into the bios. 2 ticks i'll reboot my lappy and see if it has anything like that (might not as its a lappy).
Surely before going into Advanced you are in non-Advanced?
you'd have thought so but no. I hit del and it takes me to a set up screen. it then gives me Standard CMOS features - Advanced Bios features etc but no "standard" version
Standard cmos features is standard :)
I just shut down and went back to the start up menu again and looked at the CMOS options. they are:
system time
system date
IDE Device Config
I then looked at the Integrated peripheral menu as the description said something about USB. It shows the following:
Onboard FDC - Auto
" serial port 1 - Auto
" " " 2 - auto
Parallel port - Auto
Par port mode - ECP
Midi port - disconnected
game port - disconnected
Onboard IDE - Both (other options Disabled, Primary, Secondary or both
You wont be far wrong if you assume that the above means FA to me :D
Well, after looking at every available screen, I finally gave up the ghost and got a USB to PS2 adaptor. I reckon that the mobo is so old, it doesnt have the features we all expected (at least that's my excuse and I'm sticking to it) :D.
I now have a seperate problem (again eh?) in as much as I am now getting the dreaded blue screen crash quite regularly. I "think" it is to do with the recently fitted new RAM as the only other thing changed was a new DVD writer - but I cant be certain.
So, methinks I should now take it back to the shop that fitted the RAM and ask him to investigate - what thinks you folks?
i think you should throw it in the skip and get a new one:p
Guest l-oakley
try another USB Slot. happens to my keyboard and mouse all da time.
and i wouldnt start messing around in BIOS unless you know what your doing
Lbm edit: Tranlation required. Like me, CJ is over 40 and may not quite understand ;)
all da time = all the time.
It's a USB to PS2 adapter, not the other way around.
CJ - Sounds like potentially faulty RAM. I would take it to the shop, and while there ask them to turn off the error thing.
Age of the motherboard should have no bearing on that option, I haven't seen a motherboard that doesn't have it.... other than lappy MB's. The legacy option is known to not feature with some MB's.
Either that or bin it and buy a lappy. Much less hassle lol.
