The best car of all time ?
chris aka fonz
all round package I would go for the paganni Zonda :) mental looking thing and at 400,000 dont think I will getting one any time soon :cry:
not sure on the spec........I know its got somethink like a v8 7.5ltr engine or something crazy, weighs about as much as a packet of frosties and is capable of well over 200mph
Maserati MC12 for looks,
-Ian
I prefer the Chrysler ME412.
The McLaren F1 is always top of my list. It has as much boot space as a Fiesta, it has onboard (lightweight) tools, is still the fastest thing on the road, they retrim it to your specs if you buy one second hand, you get lifetime warranty where the mechanic flies out on a chopper if he needs to, it has more seats than any other supercar.
Most of all, the whole idea of absolutely NO COMPROMISE manufacture is SOOOOOO appealing!!!
Other than that I'd like a GT40.
Check out this baby as well......one of my faves along with the Zonda
Crazy Spec :woot:
price $2 000 000 USD
engine Modified V10 w/Low Compression Pistons
position Mid Longitudinal
aspiration Twin Turbochargers
valvetrain DOHC 4 Valves per Cyl
fuel feed Sequential Multi-Point Fuel Injection
displacement 5733 cc / 349.8 cu in
bore 98 mm / 3.86 in
stroke 76 mm / 2.99 in
compression 12.0:1
power 745.7 kw / 1000 bhp @ Not Available rpm
hp per litre 174.43 bhp per litre
bhp/weight 724.64 bhp per weight
drive wheels RWD w/ASR 5.7, LSD
body / frame Carbon Fibre Body over Carbon Fiber Reinforced Plasitc Frame
front brakes Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS
f brake size 400 mm / 15.7 in
rear brakes Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS
r brake size 400 mm / 15.7 in
front wheels F 48.3 x 25.4 cm / 19 x 10 in
rear wheels R 50.8 x 33.0 cm / 20 x 13 in
front tire size 275/30-19
rear tire size 345/25-20
steering Rack & Pinion w/Power Steering
f suspension Double Wishbones w/Inboard Springs & Dampers
r suspension Double Wishbones w/Inboard Springs & Dampers
weight 1380 kg / 3042 lbs
transmission 6-Speed Race-Sourced Transaxle
gear ratios Not Available36:1
0 - 60 mph Not Available seconds
