Swampy442 Posted November 6, 2009 Share Posted November 6, 2009 Where is the box of tricks that selects the gears/ups the revs/puts the gear indicator lights on? Is it in the box itself? I had a look before I left but couldnt see anything obvious. I have a problem that when I select a gear, although it engages and the car moves, the lights on the dash dont illuminate without a bit of juggling with the lever. Quote Link to comment Share on other sites More sharing options...
Jake Posted November 6, 2009 Share Posted November 6, 2009 The box you are describing is the ECU but that's unlikely to be causing the problem with the dash illumination. Sounds like maybe an electrical contact problem or somesuch with the shifter itself. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 6, 2009 Author Share Posted November 6, 2009 So where should I be looking Jake? I know on the Soarer (Ok not the same box but similar) there was a black box the shifter connected to that took care of all that stuff, but theres nothing there on mine, it just goes straight into the gearbox. Quote Link to comment Share on other sites More sharing options...
