Hotwater
Gilham007
Was out in my 96 manual J spec TT yesterday, drove about 15 - 20 miles mostly around town so was not thrashing it. Pulled up outside my mates house and when I got out the car I heard a funny noise coming from the front of the car. Lifted the bonnet and it sounded like the water was boiling in the radiator which I have not heard before. The temp gauge was the same as normal about half way and there was no water leaking any where.
Is this normal or do I have a problem?
Cheers
Terry
Maidstone
Don't want to over complicate matters and you need to check all the obvious stuff first but I had this when I was running too lean on fuel when on a long journey.
Car was bubbling and the overflow pipe was spurting. Turned up the fuel on the S-AFC and all was well.
I have had a new cap or so the garage said when I bought it, If the head gasket had gone surely there are other symptons like over heating as well as getting you can see white gunk in your oil. This was from my Renault 5 turbo so could be different in something a lot more complicated like a supra.
How can I tel if the rad cap has gone ?
BHG can cause oil and coolant to mix, but more common on the supras (mk3's and 4's noth do this when they go) is that the coolant passage blows into the combustion chamber. Your oil isn't contaminated with white gunk, but you'll lose lots of coolant, overheat, and blow white smoke out the exhaust.
Sounds more like a problem with the coolant system to me. A rad cap is about £3, change that even though the garage said they'd changed it. It's the most likely culprit and the cheapest thing to eliminate.
Thanks for the advice I will buy a new rad cap. Next question is can I get one from a main dealer or can anyone recommend somewhere else. All new to this and don't know of many places to get parts from.
I spoke to the bloke who owns Torque IC in ashford and he said he can service etc has anyone used them before.
Just one more question I have a hks turbo timer but because of the new alarm I had fitted I can not use it as the alarm does not arm with the engine running. Is it worth having havng this done or do they not make a difference.
Sorry- link doesn't work....here's the post...
Overheating caused by yesterdays weather
Whilst driving to Elvington yesterday, I was happily driving uo the M1 at a steady 3,500 rpm when I happened to notice that my temp gauge was starting to climb.
It continued to climb until the needle was just under the red mark by which time I had both slowed to about 2,000 rpm and turned the heater on to maximum, and the temp went almost back to the middle although visably fluctuating a bit.
I stopped at the next service station to discover that my front air intake, that has a mesh grille covering it, was completely covered/full of leaves, twigs and branches!
After scooping out all the debris, I carried on up the motorway with no problems. All back to normal.
It's obvious when you think about it, but worth remembering if you have to drive in these conditions, to pull over every now and then to check the front intake.
Considering what happened to other people driving yesterday, I got off very lightly.
Terry, have you used any water at all? Is the expansion tank still at normal level. Also take the rad cap off when cold and check that it's full to the top.
When it's gurgelling carefully pull the top of the expansion tank off and see if it's blowing steam out of the pipe rather than sucking water back in.
If you drive HARD for a few minutes does the temp move from 1/2 way at all?
How long does it take to get to normal temperature?
What colour is the coolant in the expansion tank?
Cheers for the advice, The car has only done 49 000 miles, and was supposed to have been serviced before I bought it. I might have a look at the leaves as I live out in the sticks which is full of leaves etc.
Not to sound stupid but where is the expansion tank as I have no clue about mechanics at all.
Guest Martin F
Right at the front inbetween the bonnet prop and the nosecone (non-technical locators there :D ).
It is a white plastic bottle with two pipes connected to the cap.
