Stock exhaust gaskets?
Homer
2nd exhaust question of the evening :D
When using a stock exhuast are the gaskets required to get a proper seal? I've only used firegum on but they are not sealing.
I have no experience with the stock exhaust and the flanges look like they might need a gasket, can anyone confirm?
They are essential I have three here somewhere, if you want them:D
  • 1 month later...
I have good used O rings, and some new, early type OE gaskets. What exactly do you need?
Just sent you an email Chris :) For info I need:
- 1st -> 2nd cat gasket/o-ring
- 2nd cat -> stock mid pipe gasket/o-ring
- 2x stock mid pipe -> back box gaskets
Not sure if it's worth mentioning but the cat back is a stock early TT jspec one, the two cats are NA ones.
  • 2 weeks later...
After a bit of messing about I ended up buying new ones (long story and I'm sorry to mess you about Chris :( It wasn't intentional)
They appear to be compressible ones (see pic) as Chris had mentioned, but should exhuast gum paste be used with these? I couldn't find a reference to the exhaust fitment instructions in the service manual...
TIA :)
If the seats in the manifold elbow recess or the cat recess are corroded, use paste, if they are perfect, fit dry.
The cat recess's had only specs of corrosion but were in near mint condition (before I plastered them in paste the first time round, whoops!). I'll clear it all out and see how it looks. The cat back joints looked almost brand new.
Thanks Chris :)
  • 1 year later...
