just a diff quicky
hodge
Guest SupraGTE
no the donuts are different. where the propshaft meets the diff...the 3 17mm bolts...are spaced differently between the 2. na and tt are different.
Thank you keron
,so you can not but a NA diff on an auto TT?
Guest SupraGTE
My plan is to use an auto TT diff on the car even though I'm going 6 speed. Apparently there more torquey.
I guess I need to buy a diff then if the N/A diff is no good.
but can you not use the rear section from the NA prop and the front from the 6spd prop
  • 1 month later...
I run an auto TT LSD and the V160 6 speed box. I agree with Dude, if you have a standard rev limit and modest power the auto diff will be a retrograde step. You will see higher rpm at cruising speed and obviously across the entire rev range. With a big turbo and high rpm limit circa 9000rpm, the TT auto box V160 combo is great, they go very well together.
The 5 speed box will not take 500 bhp for long. Much better to get a 6 speed box.
i no the 5 speed wont take 500 but how will the tt auto match up to it. is it true that the tt auto diff has the same finale drive as the open na diff? and will the driveshafts match upto it along with the prop ?
Driveshafts I think will, the prop prob not so just get the back half of the matching tt prop
