MrRalphMan Posted November 4, 2009 Share Posted November 4, 2009 Hi, We are looking at putting our LCD up on the wall and to do this we'll need a channel cut into our concrete floor to get the relevent cables from the front of the lounge to the middle (Past a door). It will need a channel cut into the floor of about 1.5m to 2m, with possible a 90o bend about 1m in. It would also need to have a cover so we didn't fall down it when we walked over it. The cables that would need to be run down it would be. 2x Satellite Feed Cables (For Sky HD) 1x Co-Axel (For TV signal) 1x Power lead. We have been quoted £120 for this, does this sound about right? Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 4, 2009 Share Posted November 4, 2009 Concrete floor? sounds dirt cheap to me. Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted November 4, 2009 Author Share Posted November 4, 2009 It's a builder friend of Laura's brother, but just wanted a second opinion. Cheers. Paul. Quote Link to comment Share on other sites More sharing options...
Rob Posted November 4, 2009 Share Posted November 4, 2009 You'd be hard pressed to buy your own chaser tool for £120. (Awaits AV buffs to start banging on about putting the power lead in with the signal leads) Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 4, 2009 Share Posted November 4, 2009 Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted November 4, 2009 Author Share Posted November 4, 2009 You'd be hard pressed to buy your own chaser tool for £120. (Awaits AV buffs to start banging on about putting the power lead in with the signal leads) Yeah, I don't have much choice but to run it along with the others.. Quote Link to comment Share on other sites More sharing options...
Shadow Beast Posted November 4, 2009 Share Posted November 4, 2009 Segregated (Sp) trunking will do the trick run the power cable in one compartment and the AV stuff in the other, the distance is minimal so you shouldn't get any interference. Richie Quote Link to comment Share on other sites More sharing options...
DODGYDODDS Posted November 5, 2009 Share Posted November 5, 2009 £120 bargain Quote Link to comment Share on other sites More sharing options...
