Jurgen-Jm-Imports Posted November 4, 2009 Share Posted November 4, 2009 Car in question is this one.. http://www.jm-imports.co.uk/cardetails/toyota/2009/SUPRA20.html we want to keep the original turbos in place.. so what is needed to achieve the goal of 800 850 bhp.. injectors, plenum, uprated fueling system and probably maybe changing the compressor sizes to 20g if they are not that already. would love opinion of members on what you recommend we go for. am also thinking of fitting the solaris ecu for the customer.. what injectors ? what plenum ? anything else i have missed or you can suggest. if your wondering WHY well its what the customer wants, so i need your advice and recommendations on particular products,. thanks Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 4, 2009 Author Share Posted November 4, 2009 current spec 3.1 Litre Full Tune Engine by Front Row (Around 15000 kms ago) Carrillo Conrods 87mm Forged Pistons 272 Camshafts Twin Greddy TD05 Turbos (Polished) Dual Waste gates Lightweight Bonnet Polished Intake Plenum Oil Cooler ATS Mutliplate Clutch Aftermarket LSD Earls Lines and Connectors in Engine Room Uprated Fuel Pump Braided Top Rad Pipe Custom Painted Cam Gear Cover Polished Cam Covers Cusco Front Strut Brace Massive Alloy Koyo Radiator Large Front Mounted Intercooler and Custom Piping Apexi Dual Induction Filters Custom Suction Pipes Aftermarket Manifolds Aftermarket Front Pipes SARD 850cc Injectors Custom Turbo Heatsheilding Cusco Rear Strut Brace Front Row SPL Apexi N1 Coilovers Bestex Springs Cusco Pilo Uppers Supra Large Model Calipers Rear Stainmesh Brake Lines Uprated Rear Rotors Alloy Rear Diffuser Abflug Front Aero Bumper Custom Front Row Exhaust System Brembo F50 Brake Kit ARC Front Anti Roll Bar Adjustable Fuel Pressure Regulator HKS FconV Pro 7 Point Roll Bar with Padding Recaro Bucket Seat for Driver Willans 4 Point Harnesses Recaro Passenger Seat For Passenger 18" BBS LMs Momo Suede Steering Wheel HKS EVC Boost Controller Greddy Oil Temp Gauge Greddy Oil Pressure Gauge Greddy Water Temp Gauge Greddy Boost Gauge Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted November 4, 2009 Share Posted November 4, 2009 so what is needed to achieve the goal of 800 850 bhp.. I'm no expert Jurgen, though you'd never know that to look at me;), but if I was to hazard a guess I'd imagine £30-40 grand would help certainly. Quote Link to comment Share on other sites More sharing options...
Kirk Posted November 4, 2009 Share Posted November 4, 2009 oh so its you or a friend of yours who's bought this bad boy you might be favoured speakin to ken henderson, his TT supra runs 1100hp or something like that but with no doubt he'd be the man with the know how Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted November 4, 2009 Share Posted November 4, 2009 Off the top of my head, bigger injectors (1000cc plus), lots of boost and new trousers. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 4, 2009 Share Posted November 4, 2009 I think you're going to be limited to what the TD05 are capable of flowing, i suspect your only option will be to go up in size, plus the obvious like injectors fuel system etc. Quote Link to comment Share on other sites More sharing options...
johnny g Posted November 4, 2009 Share Posted November 4, 2009 I think you're going to be limited to what the TD05 are capable of flowing, i suspect your only option will be to go up in size, plus the obvious like injectors fuel system etc. IIRC, aren't the TD05's good for around 350bhp each, maybe 400bhp each at a push. I think Ricky is right, you might have to look at replacing those... Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 4, 2009 Share Posted November 4, 2009 I would say a Greddy plenum would give the most HP per £1 at this point. As others have said, next thing is to increase boost, although I suspect these turbo's will be about maxed out if the old owner changed down for response. The fuel system would hopefully support an increase of boost as it is, so long as the last owner didn't change it too much when he went for smaller turbos. A well sorted progressive nitrous system might be an idea on this one, as there's no way you'd be able to use even half of the available HP all of the time anyway. The Solaris should be capable of managing this. Other setups for the new owner to consider might be to fit a 3.4 litre stroker kit (which would give a quite frankly crazy spool on these turbos) or even one of those Boostlogic compound kits. Either of these methods would be rather expensive though, especially the compound kit as it hasn't been tested on a RHD car yet. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 4, 2009 Author Share Posted November 4, 2009 IIRC, aren't the TD05's good for around 350bhp each, maybe 400bhp each at a push. I think Ricky is right, you might have to look at replacing those... so in theoory 800 is possible on current set up Quote Link to comment Share on other sites More sharing options...
johnny g Posted November 4, 2009 Share Posted November 4, 2009 so in theoory 800 is possible on current set up I'm not guarenteeing that, that I think it's possible. Would it not be better to have a list made of the required parts to get 1000bhp, then deduct what you already have? I'd speak to Chris Wilson, Paul Whiffin, Dude @ AFR, etc - those who've built the cars previously. We're just speculating based on "knowledge" we've gained from reading many threads. Those guys have done it. I think you're probably looking at a couple of Bosch 044's, some -8AN fittings and lines, 1000cc injectors, Titan Rail etc. Turbos, if you want to stay twins, you need a 500bhp capable singles, which puts you in the high GT30xx series or lower GT35xx - then space is the issue. Maybe a single GT4202R with some progressive NOS to aid the low-end? There's all sorts of permutations, but essentially it boils down to budget and how you want the car to drive. 1000bhp out of a 3ltr lump will have lag - how much depends on how you manage it, I guess. Sorry for rambling! Quote Link to comment Share on other sites More sharing options...
martini Posted November 4, 2009 Share Posted November 4, 2009 We could ask KDW... Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted November 4, 2009 Share Posted November 4, 2009 Lee P knows a bit about big twins. If you buy this book there's a bit in the back about a Supra making 1100rwhp and how it was built. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 4, 2009 Share Posted November 4, 2009 I'm not guarenteeing that, that I think it's possible. Would it not be better to have a list made of the required parts to get 1000bhp, then deduct what you already have? I'd speak to Chris Wilson, Paul Whiffin, Dude @ AFR, etc - those who've built the cars previously. We're just speculating based on "knowledge" we've gained from reading many threads. Those guys have done it. I think you're probably looking at a couple of Bosch 044's, some -8AN fittings and lines, 1000cc injectors, Titan Rail etc. Turbos, if you want to stay twins, you need a 500bhp capable singles, which puts you in the high GT30xx series or lower GT35xx - then space is the issue. Maybe a single GT4202R with some progressive NOS to aid the low-end? There's all sorts of permutations, but essentially it boils down to budget and how you want the car to drive. 1000bhp out of a 3ltr lump will have lag - how much depends on how you manage it, I guess. Sorry for rambling! We could ask KDW... Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 4, 2009 Share Posted November 4, 2009 so in theoory 800 is possible on current set up In theory, but they will be at there limit and very probably out of there efficiency range, so you are actually loosing out on the limit, much better to have a little puff left than not enough;) Quote Link to comment Share on other sites More sharing options...
dude Posted November 4, 2009 Share Posted November 4, 2009 What HP is it running now ???? Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 4, 2009 Share Posted November 4, 2009 What HP is it running now ???? 650hp Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 4, 2009 Share Posted November 4, 2009 650hp Are you the new owner? Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 4, 2009 Share Posted November 4, 2009 Quote Link to comment Share on other sites More sharing options...
dude Posted November 4, 2009 Share Posted November 4, 2009 @ what boost ???? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 4, 2009 Share Posted November 4, 2009 You lucky man. Nice car! Quote Link to comment Share on other sites More sharing options...
dude Posted November 4, 2009 Share Posted November 4, 2009 Car in question is this one.. http://www.jm-imports.co.uk/cardetails/toyota/2009/SUPRA20.html we want to keep the original turbos in place.. so what is needed to achieve the goal of 800 850 bhp.. injectors, plenum, uprated fueling system and probably maybe changing the compressor sizes to 20g if they are not that already. would love opinion of members on what you recommend we go for. am also thinking of fitting the solaris ecu for the customer.. what injectors ? what plenum ? anything else i have missed or you can suggest. if your wondering WHY well its what the customer wants, so i need your advice and recommendations on particular products,. thanks Dude your HKS F-Con Pro is IMO a better ECU than the Solaris, provided it is mappablke outside of Japan, if it is get a knock amp and the extra O2 sensor and you won't want anything else. Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 4, 2009 Share Posted November 4, 2009 @ what boost ???? 1.6 bar apparantly Quote Link to comment Share on other sites More sharing options...
dude Posted November 4, 2009 Share Posted November 4, 2009 Do you have a budget in mind dude??? Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 4, 2009 Share Posted November 4, 2009 You lucky man. Nice car! Thanks mate... I had a purple t51r of jurgen and that was running 650ish and that just wasnt enough Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 4, 2009 Share Posted November 4, 2009 Do you have a budget in mind dude??? Its flexible to a degree.. I want to keep a reasonable spool.. So I am for sure thinking of a plenum like Jamies, 1000cc fuel kit etc etc... Im not sure how much different the extra 100cc of displacement will effect spool time ( i would of thought marginal) Quote Link to comment Share on other sites More sharing options...
