remove stock spoiler
Zofix
What a PITA to get that plastic trim off the hatch! It is held buy 10+ metal clips and when I took it off 3 of the metal clips feel into the hatch and I cant reach or see them!
Did anyone else have this problem and what did you do?![ANGRY][/ANGRY]
Yep, had the same issue twice. Aaalway happen when you remove the spoiler :)
As mentioned above, get a good telescopic magnet and spend a few minutes fishing. If its stuck in there, I've had luck with closing the hatch and hitting it by hand to rattle the bolt loose again.
The plastic things needs to be removed too? or is it just clips? I removed the 4 bolts, 2 in each side.. Where do you want me to hit it from.. It can no way be just ripped off I really used alot of force.. I think something will get damaged..
