This set up work??
hp006
I have posted before but with no answer. With some research i have found this on the web
http://www.max-boost.co.uk/max-boost/supra/boosting_the_beast.htm
From the An even better way to increase low-rpm boost
Is this a way i can install my aem boost controller? Where it says to put the manual boost controller can i replace this with the solenoid from the aem boost controller?
I have tried the search function on here and google.
There is no results as to how to install the aem boost controller on the tt supra
If someone can point me in the right direction then i will sit in the garage and tinker with the car some more
If you have 2 aem's then i guess you could do it. There may be a way to hook it up to run with 1 aem but whatever you set the boost at is what they will both run at, as in 1.2 when the first is on and 1.2 when they are both on.
I don't think the 1st tubby would like that much. If you do a search and find the discussions i had on it, i was advised against even bothering to do it as it offered VERY little gain... if any.
