paulj1 Posted November 2, 2009 Share Posted November 2, 2009 Hi I'm in need of a new clutch for my 1996 tt 6 speed with bpu but having just found out me and the Mrs are expecting a little one I'm on a fairly tight budget any ideas please Thanks Paul Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted November 2, 2009 Share Posted November 2, 2009 Stock toyota one. Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted November 2, 2009 Share Posted November 2, 2009 stock one will hold the power ok think its cheapest option. best of luck with baby Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 3, 2009 Share Posted November 3, 2009 I have one of my uprated, buy stcok based units built and ready to go. See below if interested: Available now: Uprated MKIV TT clutches. I use the stock, brand new driven plate, as it is correctly balanced, doesn't judder and will hold all but mega torque highly modded engines or cars used for drag racing. I modify a stock brand new cover to give more clamping force. The reason I tooled up to do these is some of the aftermarket US clutches I have fitted SEEM to be built from used cover assemblies with reground friction surfaces, and a stronger spring. I have had hellish trouble getting these to fully release, because due to this seemingly thinner cast iron friction face, the geometry of the clutch goes to pot, and being a pull type clutch (the hydraulics pull the bearing away from the engine, rather than the more normal push type) it is a lot harder to effect a cure. For 475 pounds, no VAT to pay, you get a brand new driven plate, a brand new modded cover, and a brand new release bearing. I would rather fit myself so any complaints are down to me, I see too many clutches juddering due to someone without the right gear allowing the gearbox input shaft to bend the driven plate. The gearboxes weight is allowed to swing on the plate centre, bending the centre, or clutches fitted to patently buggered flywheels. However, I might be persuaded to sell to people using bona fide fitters to install one. Toyota use a dual mass flywheel (the flywheel is in 2 parts, an inner and outer assembly, damped in the middle) which is now showing signs of wear causing a lot of rattle when idling or on very light throttle openings. For God knows what reason they are charging about 270 quid for a new one, they look more like they should be over 500 to me, but don't say anything :-) So if the flywheels old enough or abused enough to be scored it's best replaced. If pressed I will sell the clutch kit, which includes a new release bearing for a 3rd party to fit. Fitting by myself will cost £175. Reply privately if interested please. [email protected] Quote Link to comment Share on other sites More sharing options...
