Copy dvd to PS3
wile e coyote
For DVD's i would go with Divx or Xvid. Both can compress a DVD up to 700mb and still have reasonable quality. I would recommend 1-1.2gb per compressed DVD movie though, just so the quality is good.
Handbrake should work fine. There are a few 1 click rippers but I'm in work just now so can't have a look.
I'm surprised you are getting stuttering. Only things that stuttered on my PS3 was HD flicks.
Having a house built so will put a couple of ethernet cables in
Think Wez means the power point access points. It plugs into a power socket, you plug your net into it and then you put other access points around your house... plugged into sockets.
They use your mains power wiring to fire the signal around the house. Not far off of Lan speeds too.
