Hello, problems already!
Guest vikerz18
Guest vikerz18
Hello every1.
Recently bought a mk 4 auto N/A supra to get me started. Had wanted one for ages and finally managed to get my hands on it. Nice car. needed a little tidying but turns heads :)
Pretty standard. Just bought some 18" deep dish rims for it and a carbon interior to start with.
1 problem that i cant figure is on the dash it keeps flashing overdrive off when it is on. If i turn the overdrive off it says o/d off and doesnt flash.
Im not sure what it is, but i wouldnt of thought its a loose connection because its a perfectly timed flash on and off constantly.
It doesnt happen all the time and doesnt affect the drive but its a bit annoying.
The only other thing is i need a drivers side electric window regulator if anyone has one?
Any help will be brill.
Many thanks
Edited by vikerz18 (see edit history)
Hello and Welcome TTC.
It could most likely he a loose wire, under the gearbox cover, just check you have no loose wires. This happens to me if I take the gearbox cover off and drive around (did it twice when changing my dash).
Put up a wanted post for a window regulator or get in touch with one of the traders on here, I am sure they can provide you with one mate.
