Fuel Pump (uk), Coil Pack, TPS aand MAF (vvti)
legendswraith
Still have a Walbro 255lph fuel pump, a vvti Throttle position sensor and MAF sensor for the vvti available.
The pump only did about 50 miles in the car due to being the wrong spec and causing issues. The TPS was bought brand new to sort the issues out the fuel pump was causing as was the MAF :rolleyes:
Looking to either exchange the fuel pump for a JSpec version that hasn't been running for years or sell it.
£50 for the pump (in box with filter sock etc)
£60 for the TPS (its brand new)
£25 for the MAF sensor
£20 for the vvti Coil pack
All prices include the postage unless you live in foreign climes
Tghe pump didn't give the issues it was the fit to the cradle in the vvti aristo. As the pump does not fit quite right into the cradle it was pushing itself off the connectors and leaking the pressure back into the tank rather than giving the pressure at the rail.
Pumps fine it was the muppet fitting it got it wrong[OOPS][/OOPS]
