Geo Posted October 28, 2009 Share Posted October 28, 2009 Can the oil pump can be changed with the sump on, or will it have to be removed as the pump is fouling on the sump, this is because the pump is larger on the inside compared to the outside face. cheers guys Quote Link to comment Share on other sites More sharing options...
Miguel Posted October 28, 2009 Share Posted October 28, 2009 In short, nope. Engine out, or subframe off job. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 28, 2009 Share Posted October 28, 2009 Yep! it all has to come off PITA of a job. Quote Link to comment Share on other sites More sharing options...
Geo Posted October 28, 2009 Author Share Posted October 28, 2009 Bollocks Cheers guys Quote Link to comment Share on other sites More sharing options...
little num Posted October 28, 2009 Share Posted October 28, 2009 http://www.mkivsupra.net/vbb/showthread.php?t=185924 here is the tread when i did mine. Quote Link to comment Share on other sites More sharing options...
Geo Posted October 28, 2009 Author Share Posted October 28, 2009 ^^^^ long did it take you dude?? Quote Link to comment Share on other sites More sharing options...
bignum Posted October 28, 2009 Share Posted October 28, 2009 ^^^^ long did it take you dude?? It was basically 2 days, a day to strip then a day to refit, looked like a nasty job tbh, i watched from the bedroom window:d Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 28, 2009 Share Posted October 28, 2009 probly something i will be tackling 1 day! woopeeee Quote Link to comment Share on other sites More sharing options...
Geo Posted October 28, 2009 Author Share Posted October 28, 2009 A long job then. Joy. Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted October 29, 2009 Share Posted October 29, 2009 what is the first sign of the pump on its way out or is there any Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 29, 2009 Share Posted October 29, 2009 what is the first sign of the pump on its way out or is there any Usually having the the front main seal keep failing is a pretty sure sign, but i guess you could suffer lower oil pressure, but i doubt it as my pressure was higher than normal yet the pump was fooked. Quote Link to comment Share on other sites More sharing options...
