NA polished intake pipe group buy!
Guest Rays the roof
1. Marco79 - polished with blue connectors
2. nevins - polished with black connectors
3. neil-na - polished with black connectors
4. mitchell9006 - chromed with red connectors
5.-welsh-stealth- polished with blue connectors
6.
7.
8.
9.
10.
been after one of these for a while! screw the box thingy&so what if it heats up a little,it wont flex like plastic =) better air flow =)
Would it not be cheaper to just buy the already made kits from ebay? They come with a crap filter but you could ditch that and use your current filter.
Approx £40 for the shiney pipe, couplers and filter etc.
I've never seen them mate, the pipe would have to be made to fit the standard box tho which I think could be a problem if the designer intended it to just fit a replacement cone job
Na, they were designed to fit with a MAF AFAIK. In this sort of application they would fit right in. No good for the TT guys though, even though thats what they are designed for.
Had a search..
http://cgi.ebay.co.uk/TOYOTA-SUPRA-TWIN-TURBO-AIR-INDUCTION-FILTER-KIT-93-99_W0QQitemZ130296480763QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item1e564683fb
If you look at the shape of the pipe... along with the couplers it will work fine :)
Might get some decent couplers though. IMO it could be used as part of the group buy. Each person buys this & Ray works his magic to make shiney and sources decent bits and bobs to go along with it. Should be cheaper than £130 though.
if your only after a polished one with connectors it's only £100 from this gb by the time you have forked out £50 for the kit, replaced the connectors and got ray to do what he does best ;) your going to be looking at the same price IMO. If this gb doesn't pan out it would definitely be the route to look into though for sure :)
I'm not in for any of it. Just thought I would put forward an idea to save you guys some cash.
I'm with "Black is the new bling" ;)
I know mate, if you hadn't pointed it out I would never have known either, I never looked past the eBay ad titles as they always specified TT lol you have highlighted a new path to the Bling ;)
Guest Rays the roof
Will you be doing a TT version of that pipe (its slightly different as i am suer you know) - I need one to complete the look.
There has been a lot of interest in the TT one too. I will be doing one of these soon ;)
Guest Rays the roof
Contacted the seller on Flea bay and asked for 10 of the pipes only, without the cheap filter on the end. Once I have this I can price up polishing/chroming and revise the price. But yes as I don't have the design and fabrication cost, they will be quite a bit less than I originally estimated ;)
Guest Rays the roof
Price will be less than originally estimated!
6.
7.
8.
9.
10.
