Stephen G Posted October 26, 2009 Share Posted October 26, 2009 I have to get some wrap for the turbo kit i have and i came across this stuff. Has anyone on here tried this brand of wrap? http://cgi.ebay.co.uk/COOL-IT-by-Thermotec-Exhaust-heat-protective-wrap_W0QQitemZ310104300727QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item4833a81cb7 Its not cheap compared to the other wrap that is for sale or is it just over priced? How much would you need to wrap a manifold and two downpipes? Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted October 26, 2009 Share Posted October 26, 2009 You would be better off with a Dei exhaust wrap kit. Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 26, 2009 Share Posted October 26, 2009 well seeming this as came up just temp coated mine today (yes i know its an NA) Quote Link to comment Share on other sites More sharing options...
JustGav Posted October 26, 2009 Share Posted October 26, 2009 I'd be interested to know how the temp coating compares to the wrap stuff. I like using the wrap personally. EDIT : temp coating? Looks like UHT paint (or not?) Quote Link to comment Share on other sites More sharing options...
Stephen G Posted October 26, 2009 Author Share Posted October 26, 2009 You would be better off with a Dei exhaust wrap kit. Who sells it? and would there be enough to do my job? Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 26, 2009 Share Posted October 26, 2009 it probly isnt as effective as wrap but for an NA it will do its job Yes UHT paint.... had some left over from a bit ago so i thought why not.... then i got carried away and painted my intake manifold.. Quote Link to comment Share on other sites More sharing options...
Stephen G Posted October 26, 2009 Author Share Posted October 26, 2009 EDIT : temp coating? Looks like UHT paint (or not?) Thats UHT paint (note the spray can in the pic) Quote Link to comment Share on other sites More sharing options...
Stephen G Posted October 26, 2009 Author Share Posted October 26, 2009 beat me to it Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 26, 2009 Share Posted October 26, 2009 I've just bought some of the Thermo-Tec wrap (50' x 2"), not sure if it's any better but it's heat rating is higher than the other stuff so I took a chance it would be better Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 26, 2009 Share Posted October 26, 2009 Thats UHT paint (note the spray can in the pic) thats actualy a can of contact cleaner i painted all my manifolds on my 1st build and i thought it looked rather good.... Quote Link to comment Share on other sites More sharing options...
JustGav Posted October 26, 2009 Share Posted October 26, 2009 I've just bought some of the Thermo-Tec wrap (50' x 2"), not sure if it's any better but it's heat rating is higher than the other stuff so I took a chance it would be better I use the thermo-tec stuff, and it does what it says it does on the packet....just watch the fibres, they get damn itchy Quote Link to comment Share on other sites More sharing options...
Supradoopa Posted October 26, 2009 Share Posted October 26, 2009 I've just bought some from Whifbitz, give Paul a shout mate Quote Link to comment Share on other sites More sharing options...
Stephen G Posted October 26, 2009 Author Share Posted October 26, 2009 thats actualy a can of contact cleaner Thats what i get for thinking i'm smart:) So guys i take it that my ebay find is a good brand, so any ideas on how much i should get? Quote Link to comment Share on other sites More sharing options...
JustGav Posted October 26, 2009 Share Posted October 26, 2009 10metres easily did the sr20 engine we had with about 1m spare...so roughly 10-12m should do it. Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 26, 2009 Share Posted October 26, 2009 I bought 50' x 1" last time and didn't have enough to wrap my manifold (I have some left over from before so it wasn't a problem). The 1" is better at wrapping the tight bends on the runners, the 2" is better for wrapping long lengths (downpipe for example) Quote Link to comment Share on other sites More sharing options...
Stephen G Posted October 26, 2009 Author Share Posted October 26, 2009 10metres easily did the sr20 engine we had with about 1m spare...so roughly 10-12m should do it. But i'm putting on twins would 12m be enough Quote Link to comment Share on other sites More sharing options...
Kev.O Posted October 26, 2009 Share Posted October 26, 2009 I bought 50' x 1" last time and didn't have enough to wrap my manifold (I have some left over from before so it wasn't a problem). The 1" is better at wrapping the tight bends on the runners, the 2" is better for wrapping long lengths (downpipe for example) Couldn't have said it better myself. I was about a foot short, but used a little 2". Here's the 1":-1" by 50'. Here's the 2":-2" by 50'. My advice would be to use gloves, and to use plastic ties to hold the wrap inplace, then use the metal ties after. It's also advisable to use plastic ties as you wrap, as the wrap starts to undo itself after a while. It's hard to get tight. Just make sure you remove all the plastic ties once you've finished Quote Link to comment Share on other sites More sharing options...
JustGav Posted October 26, 2009 Share Posted October 26, 2009 It's also advisable to use plastic ties as you wrap, as the wrap starts to undo itself after a while. It's hard to get tight. Just make sure you remove all the plastic ties once you've finished Good advice, exactly the same way I did it, just makes getting it on a lot easier... Quote Link to comment Share on other sites More sharing options...
Kev.O Posted October 26, 2009 Share Posted October 26, 2009 If you have a mask I'd wear that as well. Pulling through 10'-20' of wrap gets the fibres everywhere, and as Gav said earlier, they really itch. I used a screwdriver and pliers to get the metal ties as tight as possible. Here's the tools I used and a few progress pictures, hopefully someone might find them useful (the tape is the seal the gloves): Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 26, 2009 Share Posted October 26, 2009 thats a clean install! nice work Quote Link to comment Share on other sites More sharing options...
Andy-No-Knee Posted October 27, 2009 Share Posted October 27, 2009 If you put it on with the wrap damp it help stop the fibre problem and when it dries it slightly shrinks so adds to the tightness of the wrap. Looks good. I never took any photos of mine. I see you wrapped over the boss for a sensor, I take it you will then cut a hole in the wrap? I just weaved around it as mine had bolt holes as part of the boss and it was easier. Quote Link to comment Share on other sites More sharing options...
Stephen G Posted October 27, 2009 Author Share Posted October 27, 2009 Cheers guys for all the help and suggestions:) Quote Link to comment Share on other sites More sharing options...
Kev.O Posted October 27, 2009 Share Posted October 27, 2009 If you put it on with the wrap damp it help stop the fibre problem and when it dries it slightly shrinks so adds to the tightness of the wrap. Looks good. I never took any photos of mine. I see you wrapped over the boss for a sensor, I take it you will then cut a hole in the wrap? I just weaved around it as mine had bolt holes as part of the boss and it was easier. There's pros and cons to wetting the wrap first IIRC. The boss isn't used as the AEM sensor is in the second de-cat. Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 27, 2009 Share Posted October 27, 2009 Good thread, im looking to buy heat wrap this week as well for my NA manifold. How much do you reckon i would need just for the manifold.? Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 27, 2009 Share Posted October 27, 2009 no offence but why would you bother with the na?? Quote Link to comment Share on other sites More sharing options...
