RobAce Posted October 26, 2009 Share Posted October 26, 2009 hi all, i am am doing a 6 speed manual converion on my j spec t-61 and woz wondering if i will need to re map my e-manage ultimate or if the map for the auto will be ok thanks rob Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted October 26, 2009 Share Posted October 26, 2009 I'd have thought it'd be fine. You're not changing anything about the engine or the way it runs. Quote Link to comment Share on other sites More sharing options...
bignum Posted October 26, 2009 Share Posted October 26, 2009 But you are changing the ecu to a manual 1 right, i`d atleast get the map checked to be safe, ryans your man. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted October 27, 2009 Share Posted October 27, 2009 Auto ECU's run on manual cars as far as I'm aware, just not the other way around. Quote Link to comment Share on other sites More sharing options...
SteveL Posted October 27, 2009 Share Posted October 27, 2009 Best to get it checked as surely there will be different loads on the engine because of different gearing. Quote Link to comment Share on other sites More sharing options...
Ian C Posted October 27, 2009 Share Posted October 27, 2009 Best to get it checked as surely there will be different loads on the engine because of different gearing. ECU maps don't work like that. They have revs and they have load, which is vacuum and boost pressure. An engine is mapped for all plausible vacuum and boost pressures at all plausible revs, so while you wouldn't map 1.4bar at 750rpm, you'd probably better allow for 1.4bar at 3000rpm in case of a steep hill in 6th gear while towing a caravan. So gearing is irrelevant. -Ian Quote Link to comment Share on other sites More sharing options...
RobAce Posted October 27, 2009 Author Share Posted October 27, 2009 ECU maps don't work like that. They have revs and they have load, which is vacuum and boost pressure. An engine is mapped for all plausible vacuum and boost pressures at all plausible revs, so while you wouldn't map 1.4bar at 750rpm, you'd probably better allow for 1.4bar at 3000rpm in case of a steep hill in 6th gear while towing a caravan. So gearing is irrelevant. -Ian so your saying it should be ok but might need a tweek Quote Link to comment Share on other sites More sharing options...
Ian C Posted October 27, 2009 Share Posted October 27, 2009 The logical part of me says it'll behave exactly the same. The mechanically paranoid part of me says make sure the fuelling is alright still Quote Link to comment Share on other sites More sharing options...
SteveL Posted October 27, 2009 Share Posted October 27, 2009 ECU maps don't work like that. They have revs and they have load, which is vacuum and boost pressure. An engine is mapped for all plausible vacuum and boost pressures at all plausible revs, so while you wouldn't map 1.4bar at 750rpm, you'd probably better allow for 1.4bar at 3000rpm in case of a steep hill in 6th gear while towing a caravan. So gearing is irrelevant. -Ian .. gotcha, thanks for clarifying that Quote Link to comment Share on other sites More sharing options...
