Modified R35 GTR
erol_h
POWER ENTERPRISE NISSAN SKYLINE GT-R. TWIN TURBO & SUPERCHARGED, TEST DRIVEN BY DAI.
Nissan R35 GTR, VR38DETT, Power Enterprise QUAD-charger system (Stock IHI Twin turbo & Twin Rotrex C30-94 Super Charger: 400ps x2 flow rate, at down stream of intake) as displayed at 2009 Tokyo Auto Salon.
The system is designed for 700HP (670+WHP) with huge low to mid-range torque gain benefiting road course and time attack racers.
This kit includes, Titanium Exhaust System - highest grade titanium available for automotive market (main pipe 89mm and dual-twin 70mm outlet), reinforced hose & T-bolt kit, and P-MAP (Newly developed piggy-back/Sub-ECU) pre-programmed and programmable to re-calibrate fuel (Air Flow less "D-Jetronics" w/ self learning), IG timing, boost, speed & rev limiter, Additional injectors, Launch control, nitrous and more.
The QUAD-charger kit will be tested and tuned to perfection at several of race courses prior to the anticipated release date of April to May 2009. Dyno sheets based upon several courses will be provided for tuners base mapping.
Twin-turbo and twin-supercharged, that's impressive.
Thats also a weird blue rx7 in the background too :S
True, any idea why on the rex they have blurred out the number plate? Not like anyone can clone that car :D
The Skyline on the other had should have it blurred out for doing wrap speeds!
