Possible to merge facelift & UK lights
jevansio
All headlights (j-spec/UK spec, pre-facelift/facelift) are interchangeable with no modifications needed (although the bulbs are different for the UK/j-spec).
The facelift headlights do not include the side light inside, so you need to fit the facelift indicators/sidelights, these are not a straight swap and need the wiring splicing in for the sidelights.
Did the cars in US only get plastic then ?
With the UK car being the 'Export' model, I thought the US car would get the glass ones as well as the UK and Euro spec's ???
Hmmm, I guess the Euro spec of the 'Export' version did not get the headlight washer jets so, each market could opt for different bits I guess but, keep the same engine setup (MAF).:search:
