Broadband bits
Digsy
Okey dokey:
My local exchange for local people FINALLY got BB-enabled today (right when BT said it would be - bless them). So now I need to place my order and buy my bits.
I've already posted up here that I want an internal modem, but I'll be borrowing a mate's external frog jobby first.
A couple of Q's:
1) Will ANY modem do the job, or are there a bazzilion different protocols like there used to be with dialup?
2) Will any old microfilter do the trick? DABs sell some super-cheapo ones for about £3 but loads of people have posted up sayign they are rubbish and "don't remove the noise from the telephone line" or some such. Are they all much of a muchness, or are there really good and bad ones? I'll need two or three of the little buggers.
3) Unles sthere are any other pointers, I was pretty much going with PLUSnet's £14.99 PAYG with free install. Looks a good deal but the clawback is a bit harsh (£58.75 reducing to zero over 5 years!) Mind you if they are a good ISP I'll stay with them. I've been with Clara for that long, easily.
4) Anything else I've missed?
1. Provided the modem can PPPoA then you are okay, trust the brits to use the old protocol and not the new and more flexible PPPoE.. The external frog is as good as any really... I would stick with that rather than an internal.
2. I've used plenty of microfilters in the past, and they all seem to be much of a muchness.... I might have a spare couple at home actually from my frog modems...
3. Check out ADSLguide.org.uk, they usually have good things about all the ISPs...
4. Nope, don't think so
I am running PIPEX at home and thus far they have not disconnected me plus they are fazing out 512Kb connections in favour of 1Mb at the same price £23.44 (unmetered and i wish to point out i really dont do hours and hours of P2P stuff, Honest :read: ) and sometimes they throw out free modems etc. Tdax is correct a microfilter is a microfilter is a microfilter, sometimes supplied with adsl modem.
That's to cover the "free" modem.
No, would you beileve there's an additional £25 clawback to cover the modem, which you can turn off if you supply your own. :eek:
It's to cover activation, but five years seems a bit harsh. Very likely that most people will want to change ISP or even move house within that time.
I'd give a thumbs up to Pipex too, been with them since Sept 6th last year (when BT changed the limits) and they've been pretty good.
I was struggling with stability but registered the problems with Pipex and a BT engineer came within a couple of days. He ran loads of tests and then changed the wiring a bit and installed an ADSL faceplate, it's now rock solid and I'm nearly 7km from the exchange.
If you're a long way from the exchange, it may be worth installing an ADSL faceplate (see here http://www.solwise.co.uk/adsl_splitters.htm). Takes the need away for filters, and has helped many who have poor SNR etc.
Matt
Crikey!
Our activation fee is 50 quid as a Nildram reseller.
Nildram are ace.
With regards to lines and wires and filters and faceplates, my computer will be connected to a rather long (15m or so) DIY extension (using quality cable straight into the BT main box, as intended). Is this likely to cause problems?
Luckily the wire is all surface-mounted so I won't have to chisel the walls out if I need to replace it with something better, but my main BT box is currently in a totally different room to my PC.
Erm, nildram are now owned by pipex...
In July 2004, PIPEX Communications Group acquired The AccentUK Group for 12.9 million UKP. AccentUK remains a separate and distinct division within PIPEX and it continues to operate its all three brands, including Nildram, Trinite and Lobsterpot.
Although owned - still very seperate.
Best to 'suck it and see' mate, if you're getting drop-outs etc then give a faceplate a try, they're not expensive.
