no horn working,centrel locking not working and no warm air blowing from heater??
catfish man
hi just took my mono steering wheel to see if the horn was conected and it was:( also touched both wires together and nothing ive also checked the fuses under bonnet they are fine :(
also to my problems no warm air from heater only cold
also centrel locking is not working hmm i dont know what to do:(
1/ problems no warm air from heater--CHECK level of coolant,possible blocked heater matrix ?
2/centrel locking is not working -- check fuses in the footwell but i beleive the electric windows share the same fuse . so might be a feed problem at the switch socket.
3/ horn proberly faulty.
when was the last time they worked?
If they've all stopped at once I'd say you have a wiring fault.
Normally an earth.
When you turn the heater hot to cold or vice versa, do you hear the flaps move?
If no then that's electrics. imo
You say central locking is not working..... Off a fob or key?
Normally an earth.
key ? no fob
No idea mate, i wouldn't just stick in any old fuses though as it will either pop as you have found or it could potentially allow too much current causing a fire.
The horn will probably be fooked. Get the premium horn kit as a replacement if it is. Quick way to check is to take a wire and touch the positive wire onto its terminal from the battery.
hi i took of the horn and put direct to the battery and it worked:search:
Not so good then. Does your kick fuse box not have a lid? Should be something like this? Might be a bit different though so you might need the exact model.
Going by this it appears the doors should be 30A?
http://97supraturbo.com/Pictures%20for%20Posting/Fuse%20Location%20(Large).jpg
hmm no lid its missing only the cover :search:
got my horn working at last cheers :) now its my centrel locking i have to get working the fuse is okay i think it must behind the door pannel the problem?
If using the central locking blows the fuse, then the next step as you say would be to remove the door card. There's a guide on here on how to do it, it's pretty simple. My guess is that the +ve feed to the door locking motor has lost its insulation and is either touching the bodywork or touching the -ve feed.
