catfish man Posted October 22, 2009 Share Posted October 22, 2009 hi just took my mono steering wheel to see if the horn was conected and it was:( also touched both wires together and nothing ive also checked the fuses under bonnet they are fine also to my problems no warm air from heater only cold also centrel locking is not working hmm i dont know what to do:( Link to comment Share on other sites More sharing options...
absz Posted October 22, 2009 Share Posted October 22, 2009 1/ problems no warm air from heater--CHECK level of coolant,possible blocked heater matrix ? 2/centrel locking is not working -- check fuses in the footwell but i beleive the electric windows share the same fuse . so might be a feed problem at the switch socket. 3/ horn proberly faulty. Link to comment Share on other sites More sharing options...
stevie_b Posted October 22, 2009 Share Posted October 22, 2009 You can test the electrical feed to the horn with a multimeter: get someone to press the horn while you apply the probes. Link to comment Share on other sites More sharing options...
simonsupra Posted October 23, 2009 Share Posted October 23, 2009 hi mate, i honestly didnt know about the horn or the heaters, never used the horn and never needed the heaters, sorry bro. Link to comment Share on other sites More sharing options...
Todd Posted October 23, 2009 Share Posted October 23, 2009 (edited) Have you checked fuses in the drivers steering well? Edited October 23, 2009 by Todd oops, already mentioned above! (see edit history) Link to comment Share on other sites More sharing options...
Gambit Posted October 23, 2009 Share Posted October 23, 2009 when was the last time they worked? If they've all stopped at once I'd say you have a wiring fault. Normally an earth. When you turn the heater hot to cold or vice versa, do you hear the flaps move? If no then that's electrics. imo You say central locking is not working..... Off a fob or key? Link to comment Share on other sites More sharing options...
catfish man Posted October 23, 2009 Author Share Posted October 23, 2009 when was the last time they worked? If they've all stopped at once I'd say you have a wiring fault. Normally an earth. When you turn the heater hot to cold or vice versa, do you hear the flaps move? If no then that's electrics. imo You say central locking is not working..... Off a fob or key? key ? no fob Link to comment Share on other sites More sharing options...
Gambit Posted October 23, 2009 Share Posted October 23, 2009 Try the flaps in the heater. Link to comment Share on other sites More sharing options...
catfish man Posted October 24, 2009 Author Share Posted October 24, 2009 Have you checked fuses in the drivers steering well? found one fuse missing put in another the locks worked again but now they have stopped again:rolleyes: i may have to get the car loked at via a sparky as i dont have a clue , i only know how to cook Link to comment Share on other sites More sharing options...
Gambit Posted October 24, 2009 Share Posted October 24, 2009 Did it blow the fuse you just put in? Link to comment Share on other sites More sharing options...
catfish man Posted October 26, 2009 Author Share Posted October 26, 2009 Did it blow the fuse you just put in? yes:( Link to comment Share on other sites More sharing options...
Scott Posted October 26, 2009 Share Posted October 26, 2009 Did you just put in any fuse or one that had the right rating? Link to comment Share on other sites More sharing options...
Gambit Posted October 26, 2009 Share Posted October 26, 2009 Replace the fuse and try the car again with the horn and heating but not the central locking, if it doesn't blow you know it's your central locking..... Process of illimination. Link to comment Share on other sites More sharing options...
Scott Posted October 26, 2009 Share Posted October 26, 2009 Replace the fuse and try the car again with the horn and heating but not the central locking, if it doesn't blow you know it's your central locking..... Process of illimination. Only if he uses the correct fuse Link to comment Share on other sites More sharing options...
catfish man Posted October 26, 2009 Author Share Posted October 26, 2009 Did you just put in any fuse or one that had the right rating? 7.5 fuse Link to comment Share on other sites More sharing options...
Scott Posted October 26, 2009 Share Posted October 26, 2009 Is that the one thats meant to be used? Link to comment Share on other sites More sharing options...
catfish man Posted October 26, 2009 Author Share Posted October 26, 2009 Is that the one thats meant to be used? im not to sure ? i have no diagram of the fuses under the foot well the hazzards are working and they run on the same fuse as the horn? Link to comment Share on other sites More sharing options...
Scott Posted October 26, 2009 Share Posted October 26, 2009 No idea mate, i wouldn't just stick in any old fuses though as it will either pop as you have found or it could potentially allow too much current causing a fire. The horn will probably be fooked. Get the premium horn kit as a replacement if it is. Quick way to check is to take a wire and touch the positive wire onto its terminal from the battery. Link to comment Share on other sites More sharing options...
catfish man Posted October 26, 2009 Author Share Posted October 26, 2009 No idea mate, i wouldn't just stick in any old fuses though as it will either pop as you have found or it could potentially allow too much current causing a fire. The horn will probably be fooked. Get the premium horn kit as a replacement if it is. Quick way to check is to take a wire and touch the positive wire onto its terminal from the battery. hi i took of the horn and put direct to the battery and it worked:search: Link to comment Share on other sites More sharing options...
Scott Posted October 26, 2009 Share Posted October 26, 2009 hi i took of the horn and put direct to the battery and it worked:search: Not so good then. Does your kick fuse box not have a lid? Should be something like this? Might be a bit different though so you might need the exact model. Going by this it appears the doors should be 30A? Link to comment Share on other sites More sharing options...
catfish man Posted October 28, 2009 Author Share Posted October 28, 2009 Not so good then. Does your kick fuse box not have a lid? Should be something like this? Might be a bit different though so you might need the exact model. Going by this it appears the doors should be 30A? http://97supraturbo.com/Pictures%20for%20Posting/Fuse%20Location%20(Large).jpg hmm no lid its missing only the cover got my horn working at last cheers now its my centrel locking i have to get working the fuse is okay i think it must behind the door pannel the problem? Link to comment Share on other sites More sharing options...
stevie_b Posted October 28, 2009 Share Posted October 28, 2009 If using the central locking blows the fuse, then the next step as you say would be to remove the door card. There's a guide on here on how to do it, it's pretty simple. My guess is that the +ve feed to the door locking motor has lost its insulation and is either touching the bodywork or touching the -ve feed. Link to comment Share on other sites More sharing options...
