question about a little smoke!!
Guest grantmyra
Guest grantmyra
as above my kn4 standard n/a seems to smoke a fair bit every time its started for around 5 mins then clears away as warms up?
but if you switch off then start again still does it??
its not dark its a light smoke whitish maybe?
never had a problem with it never overheated or anything blows really hot inside
should i be worried about this as its starting to bother me a bit or is this normal in any way??
all and any answers welcome and tia:search:
At this time of year it's possibly just condensation in the exhaust.
If it happens all year round, and just at start-up, stem seals might be the culprit.
White smoke might be cylinder head gasket.
If its pretty much all the time, could be piston rings (pray its not!)
Edited by ellis
It's an NA!!! (see edit history)
Guest grantmyra
its been like this since i got it!!
and never used any water or oil, never overheated temp gauge is religious, never been oil in water or vice versa and drives ace.
just that wee bit smoke at start up.
thanks for the answers guys i appreciate it
I still say stem seals then and ignore it
Edited by tooquicktostop (see edit history)
Alot of white smoke threads start when the weather gets colder.
If it does it when switched off and on again after a long run then possibly valve stem seals as mentioned.
Try and give the exhaust a sniff when it does it to see if you can smell anything odd.
It would be FAR cheaper to get a second hand engine than do any head work or anything thats going to cost more than a couple of hundred pounds (if you replace the engine yourself that is).
If its stem seals it will smell of oil but the smoke should be blue not white! :blink:
But as said already ive not heard of N/A's suffering with stem seals like the TT's do if at all but if it is be prepared to pay about about £1000 - £1500 to have it fixed as im having mine done next week :Pling:
ok i will give it a sniff tomorrow if its the stem seals will it smell of petrol? and condensation then nothing really?
If you have cats in you may get a sweet smell. If oil is getting passed the seals then it will smell oily but not really of petrol.
Dont worry to much though either way as you will pick an n/a engine up from £50 plus
Isn't it cheaper to get a new engine?
Or pay a bit more and get a TT conversion, cost around £1700 for the parts. Somebody on here offers it.
I already have a TT so no for me :D but you may have a point for the OP!!
I think its Keron that does it on here??
