seizing brake caliper
Paul372
Hi i think my front passager side jap spec caliper is starting to seize it feels like its holding the car back and i get a bit of a juggering through the brake pedal, is there away of repairing the caliper instead of buying a new one and is it a easy job to do thanks
hi, if you do decide to replace it, i had a bit of trouble finding somewhere that would ship the caliper out without wanting the faulty caliper sent to them first. i found these guys on Ebay called Automotice Japanese Spares (http://stores.shop.ebay.co.uk/Automotive-Japanese-Spares__W0QQ_armrsZ1) and got great service, they sent out a new caliper and was recieved the next working day and i shipped my one back to them to receive a £30 rebate. so was £150 delivered i think for the new caliper, and got £30 back when i returned the sticky one.
Tis quite easy, remove caliper, Check to see if the piston in the caliper is seized by pushing it back in. Remove reservoir cap first. Secure the caliper so it can't hang on the brake line.
Then remove the carrier (2 large bolts 17mm heads and lots of torque). Pull the two seized pins out using a vice then clean them all off, inspect the rubber boots and replace if shot. Check the little rubber grommets are intact on the pins. Clean out the holes in the carrier. Grease up (I use Red Rubber Grease) and assembly is the reverse of disassembly.
Edited by Rob (see edit history)
