mark uk manual Posted October 20, 2009 Share Posted October 20, 2009 I have a uk supra and when i bought the car it came with a reciept for a reconditioned lsd, that had been fitted a few months before i purchased it. On my nissan 200sx lsd if you were to turn the prop both driveshafts would turn in the same direction, and if you were to hold one driveshaft while turning the prop the other drive shaft would stop aswell. But on the supra if i turn the prop both driveshafts go the same direction, and when i hold one driveshaft while turning the prop the other then goes backwards. Also if i turn one driveshaft the other goes the opposite way. And my 200 would both go the same direction. Could someone confirm that this is not a lsd, or do supra lsd's only work under load? Thanks mark Quote Link to comment Share on other sites More sharing options...
dude Posted October 20, 2009 Share Posted October 20, 2009 Its not an LSD its a Torsen, the only way to tell is to light it up or take it out and have a look inside, I prefer the first method!!! Quote Link to comment Share on other sites More sharing options...
Racman Posted October 20, 2009 Share Posted October 20, 2009 Yea I agree the first way is best Quote Link to comment Share on other sites More sharing options...
Racman Posted October 20, 2009 Share Posted October 20, 2009 Hey Dude I've just sussed out who you are you put my sosrer on your rollers a while ago with Luke I must pop in and say hello Im doing a 5 speed conversion which should be better next time I come up for a session only thing I need is the clutch pedal Quote Link to comment Share on other sites More sharing options...
