Guest sc300gte Posted October 19, 2009 Share Posted October 19, 2009 ok so i was drifting at a event this weekend and all of the sudden in mid drift the car lost power and now it wont start. pulled the plugs and checked for spark. nothing and i am totaly lost i checked to make sure the crank sensor hadnt worked its was lose and checked the cam sensors as well. anybody have idea? Quote Link to comment Share on other sites More sharing options...
Matt H Posted October 19, 2009 Share Posted October 19, 2009 Do you have a TT? Ignitor pack? Quote Link to comment Share on other sites More sharing options...
Guest sc300gte Posted October 19, 2009 Share Posted October 19, 2009 yea its a tt with single turbo i tried a new igniter and it didnt fix it. Quote Link to comment Share on other sites More sharing options...
michel lane Posted October 19, 2009 Share Posted October 19, 2009 no spark is usually faulty crank sensor. Quote Link to comment Share on other sites More sharing options...
absz Posted October 19, 2009 Share Posted October 19, 2009 IF its the crank sensor or feed to/from sensor then the rev counter needle when not bounce when cranking over. you should see the needle move. if thats ok then check to see that you have the positive feed to coilpacks with ignition on. Quote Link to comment Share on other sites More sharing options...
Guest sc300gte Posted October 19, 2009 Share Posted October 19, 2009 yea the needle isnt moving. i have a friend who has a sensor im goin to try that and hopefully fixes my problem Quote Link to comment Share on other sites More sharing options...
Guest Cody Phillips Posted October 20, 2009 Share Posted October 20, 2009 It may be the pickup gear on the crank sensor has come loose from the lower timing gear. I've seen this MANY times, especially if the car just randomly stops running. Have you been experiencing any misfires lately??? I always make sure and weld the pickup to the gear anytime I'm in there to avoid the popoff..... Quote Link to comment Share on other sites More sharing options...
Guest sc300gte Posted October 20, 2009 Share Posted October 20, 2009 yea i have a problem under boost like cutting out in stuff, i also had a problem with my ignition feed back wire connection was bad but fixed that a while ago and i checked it to see if mabe if came out but its still in contact but i will check that gear as much as i hate to pull all that shit off to check it lol Quote Link to comment Share on other sites More sharing options...
Guest Carfreak70852 Posted October 21, 2009 Share Posted October 21, 2009 Bump. This needs to be figured out. Got any update matt? Quote Link to comment Share on other sites More sharing options...
Guest Cody Phillips Posted October 22, 2009 Share Posted October 22, 2009 Did you make sure the gear hasn't come off ??? Quote Link to comment Share on other sites More sharing options...
Guest sc300gte Posted October 23, 2009 Share Posted October 23, 2009 yeah i had a friend tell me to check the gear and saturday im goin to take the tbelt cover off and look at it also ive heard that when you do a lot of high reving the intake cam can break? does anybody know if thats true? Quote Link to comment Share on other sites More sharing options...
trinitom Posted October 23, 2009 Share Posted October 23, 2009 i never heard that and i thing to break an intake or exhaust cam you would need revs above 10k rpm. Quote Link to comment Share on other sites More sharing options...
Guest sc300gte Posted November 2, 2009 Share Posted November 2, 2009 ok guys i got it running it was the wheel behind the timming belt crank wheel haad broke off i welded it and she is running bettere= than ever. thanks for all yalls help very appreciated Quote Link to comment Share on other sites More sharing options...
