Harris25 Posted October 19, 2009 Share Posted October 19, 2009 been through the faq`s but cant find it. 94 j spec TT manual. my headlight gone but cant get in to change it. the coolent is behind it so cant get in the back and cant find the other nut(s) that are holding the headlight unit in place. help for a noob please Link to comment Share on other sites More sharing options...
Matt H Posted October 19, 2009 Share Posted October 19, 2009 There are 3 nuts holding it in from memory. Link to comment Share on other sites More sharing options...
Harris25 Posted October 19, 2009 Author Share Posted October 19, 2009 ye where abouts? Link to comment Share on other sites More sharing options...
ShamelessTT Posted October 19, 2009 Share Posted October 19, 2009 Theres a nut down there somewhere buddy,i took both my lights out completely and its definately not a bumper off job. They are quite a tight fit aswell, good pull is required. Someone will be along to tell you where, but get a light and it should be fairly obvious.....he says! Link to comment Share on other sites More sharing options...
Harris25 Posted October 19, 2009 Author Share Posted October 19, 2009 well this was my reasoning but i been stood on my drive looking pathetic for long enough so come in and get in the forum Link to comment Share on other sites More sharing options...
Harris25 Posted October 19, 2009 Author Share Posted October 19, 2009 bump sorry need to go out hurry Link to comment Share on other sites More sharing options...
merckx Posted October 19, 2009 Share Posted October 19, 2009 (edited) There're two nuts and one bolt, all 10mm. The two nuts are at the wing side of the headlight, one above the other. The bottom one is slightly more awkward, I normally use a small socket wrench with a universal joint. The bolt is on the top next to the radiator, easy to get to. You may have to jiggle the headlight a little whilst pulling it forward to remove it. Edited October 19, 2009 by merckx (see edit history) Link to comment Share on other sites More sharing options...
Matt H Posted October 19, 2009 Share Posted October 19, 2009 ye where abouts? From memory; they are at either end of the lights, two nearest the wing and one closest to the rad. They should not be that hard to find. The one at the bottom closest to the wing is probably the one yor are looking for. Once out you can pull the light outwards. Link to comment Share on other sites More sharing options...
Harris25 Posted October 19, 2009 Author Share Posted October 19, 2009 right ok cheers guys back to the grind Link to comment Share on other sites More sharing options...
Matt H Posted October 19, 2009 Share Posted October 19, 2009 right ok cheers guys back to the grind Don't come back until you've got them out Link to comment Share on other sites More sharing options...
j1mb0b1 Posted October 19, 2009 Share Posted October 19, 2009 Its easy bud I will pop down and show you if you like iam only down road from you . Link to comment Share on other sites More sharing options...
