guye_d Posted October 19, 2009 Share Posted October 19, 2009 Hey Guys, Finally have my emanage ultimate up and running nicely on the vvt-i single. Just one question and I should be good to go. I would like to verify that i have knock setup correctly. Currently I have it tapped to the intake temp sensor to read knock. I noticed recently that Greddy sells a Knock sensor adapter which is recommended for the T-17 harness which is the vehicle specific harness for the vvt-i supra. Is there any merit to purchasing this? Does it add any value over just tapping? Thanks Dudley Quote Link to comment Share on other sites More sharing options...
chrispot Posted October 21, 2009 Share Posted October 21, 2009 the intake temp sensor does not read engine knocking, i dont know where there are on the supra, normaly on the block near the top, have a look on the web for knock sensors and you will see what one looks like, the cable from the sensor should be shielded i think, have you got info on the vvti ecu this should tell you what wire it is, if not i will check to see if i have info, regards chris Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 21, 2009 Share Posted October 21, 2009 You can access the factory knock sensor wire at the ECU where you have your EMU plumbed in, after that its just a case of selecting the option in the setup menu. Quote Link to comment Share on other sites More sharing options...
