Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 Hey guys, bought a supra 2 months ago. First time I owned a supra. She is a n/a. She failed mot. The mot station said that the exhaust is TOO LOUD. So we lifted her up and the exhaust is still stock TILL the 2nd cat (or box or something). After the 2nd cat previous owner made a straight 3" pipe till the end. The 3" pipe he installed after the 2nd cat or whatever it is, is pretty much corroded and have about 5-8 small holes in it. The mot station said that he cant perform emission test because of holes. Any suggestions? Can i find the part of the exhaust from the 2nd cat till the end. The original part of the exhaust is still in good condition and not corroded (that is from manifold till the 2nd cat/box ) Thanks Quote Link to comment Share on other sites More sharing options...
keron Posted October 15, 2009 Share Posted October 15, 2009 suppose you can either patch it up or get another cat back exhaust system...might be worth getting another cat back system tbh. especially if your keeping it.. Quote Link to comment Share on other sites More sharing options...
Dave17 Posted October 15, 2009 Share Posted October 15, 2009 Get the 3inch section chopped off and replaced....or see if you can get it welded? Quote Link to comment Share on other sites More sharing options...
keron Posted October 15, 2009 Share Posted October 15, 2009 something like this...it will never rust! and is cheap too http://cgi.ebay.co.uk/MKIV-Toyota-Supra-93-98-TRD-style-stainless-exhaust-3_W0QQitemZ170387615881QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item27abe4b089&_trksid=p3286.c0.m14 Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted October 15, 2009 Share Posted October 15, 2009 Loads of cat back exhausts available matey. Check http://www.whifbitz.co.uk Quote Link to comment Share on other sites More sharing options...
AndyT Posted October 15, 2009 Share Posted October 15, 2009 Put the second cat in or find a "nice mot man". NAs are notoriously loud but I don'ts see any DB meters anywhere. Quote Link to comment Share on other sites More sharing options...
Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 Get the 3inch section chopped off and replaced....or see if you can get it welded? Thats what I was thinking but am afraid that she will fail emission test then :S As far as I am concerned she has not been suped up in any way except for a hks mushroom induction filter ... Anyways its not like you can supe up much an N/A without installing turbo. You think she will pass without the 3rd muffler/cat .. dont know what it is. Do you think she will still pass the noise test if i remove the corroded piece and install a 2.5 or 2" straight pipe? Quote Link to comment Share on other sites More sharing options...
Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 she has got 2 cats/boxes out of the original 3. she is missing the last one right before muffler tip Quote Link to comment Share on other sites More sharing options...
Dave17 Posted October 15, 2009 Share Posted October 15, 2009 Well i would have thought it would quieten it down a bit not having holes in it yes. As has been mentioned it may be time to consider a new exhaust entirely. There are only 2 cats on a supe, and since it's an na they do like abit of backpressure rather than a totally freeflowing exhaust. If it was me i'd probably go for a new cat back exhaust, you can still get ones that are loud and should pass your tests, just won't be as defeaning as your current one must be. Quote Link to comment Share on other sites More sharing options...
Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 Thanks guys for your help. Hope she passes on emissions now..:S Quote Link to comment Share on other sites More sharing options...
Guigsy Posted October 15, 2009 Share Posted October 15, 2009 she has got 2 cats/boxes out of the original 3. she is missing the last one right before muffler tip the last box isnt a cat. There is one right up close to the engine. andother in the middle of the car. the backbox is just a silencer. Quote Link to comment Share on other sites More sharing options...
Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 yeah its missing that back box (silencer) but has got both cats in.... if i remove the straight pipe and weld another straight pipe with about 2.5" diameter. Do you think it will pass emission and noise test? Thanks Quote Link to comment Share on other sites More sharing options...
AndyT Posted October 15, 2009 Share Posted October 15, 2009 yeah its missing that back box (silencer) but has got both cats in.... if i remove the straight pipe and weld another straight pipe with about 2.5" diameter. Do you think it will pass emission and noise test? Thanks Not many exhausts out there without a silencer bud. Quote Link to comment Share on other sites More sharing options...
Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 i was just thinking of welding a normal straight pipe....like REALLY STRAIGHT PIPE...2.5" diameter all the way through Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted October 15, 2009 Share Posted October 15, 2009 2 cats and no silencer... and it failed the MOT? Quote Link to comment Share on other sites More sharing options...
AndyT Posted October 15, 2009 Share Posted October 15, 2009 Hey guys, bought a supra 2 months ago. First time I owned a supra. She is a n/a. She failed mot. The mot station said that the exhaust is TOO LOUD. So we lifted her up and the exhaust is still stock TILL the 2nd cat (or box or something). After the 2nd cat previous owner made a straight 3" pipe till the end. The 3" pipe he installed after the 2nd cat or whatever it is, is pretty much corroded and have about 5-8 small holes in it. The mot station said that he cant perform emission test because of holes. Any suggestions? Can i find the part of the exhaust from the 2nd cat till the end. The original part of the exhaust is still in good condition and not corroded (that is from manifold till the 2nd cat/box ) Thanks Actually, how can you fail on noise when bikes are far louder? I'm not sure you can. All I've ever heard of is rules for racetracks. Quote Link to comment Share on other sites More sharing options...
Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 yep ... but never got tested for emission...it only failed on noise levels due to holes I HOPE!!! Quote Link to comment Share on other sites More sharing options...
Dave17 Posted October 15, 2009 Share Posted October 15, 2009 With both cats in place it should pass without issue on emissions, your probably still going to need a silencer on the rear though.. Quote Link to comment Share on other sites More sharing options...
Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 dont know how they calculate noise levels though....there is no meter or figures... Quote Link to comment Share on other sites More sharing options...
HadeS Posted October 15, 2009 Share Posted October 15, 2009 I have got stock silencer if you will be intrested but dont know about posting Quote Link to comment Share on other sites More sharing options...
Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 really? how much you looking for it? the car is in bournemouth.... you have the complete exhaust (That is from muffler tip till the second cat) Quote Link to comment Share on other sites More sharing options...
HadeS Posted October 15, 2009 Share Posted October 15, 2009 Thats 200 miles out of me :/. I have only back silencer. But if you would like to get pipes from 2nd cat, ask Hoff - he got them. (if has not sell already) I would take 10-20 quid for it but it's guite far:/ Quote Link to comment Share on other sites More sharing options...
Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 is it possible you get me a shipping quote to bournemouth? I will let someone install some kind of pipe whats your opinion about that? Quote Link to comment Share on other sites More sharing options...
HadeS Posted October 15, 2009 Share Posted October 15, 2009 I bet that is about 10-15kg? Meaby some1 else have stock exhaust for sale. If you will not find anythink for next few days closer to you I'll try to quote it. Quote Link to comment Share on other sites More sharing options...
Guest atheuma Posted October 15, 2009 Share Posted October 15, 2009 quote me anyway....my postcode is BH11 9LX Quote Link to comment Share on other sites More sharing options...
