No 1 and 2 vehicle speed sensor
Guest putputcar
Guest putputcar
Hi all, Can you change out the vehicle speed sensor on the transmission o without take the transmission off?
At first my speedometer and odometer are registering any speed and trip. After I open up the dash, clean up the solders a little bit, so now it odometer is registering but the speedometer still not reading at all.
I think the speed sensor is bad.
I’m new to the supra, Let me know what you think I should do first. Thanks
Guest putputcar
I take it you have an auto? If so yes, you can remove it with the gearbox in. Its at the rear of the 'box where the output shaft is
yes, it's an auto. Thanks for the input.
