supra wont start !!
supratony
Hi all, supra finally stopped working yesterday its not being used much at the moment so last battery was getting weak. i tried jump starting it and charging it neither worked, so bought a new battery today still nothing.
i get no dash lights or no clicking when turning the key its just dead!
had new starter motor about a year ago but i cant understand why theres no dash lights or anything.
any ideas?
i will try and check these things tmoz! where will i find the fuses? is it a common thing to have no lights on dash and not turn over?
It is if the battery is flat :D
The fuses are in the engine bay under a black plastic cover just behind the battery.
Sounds like you have a main earth fault.
I have to agree. If your battery's charged and none of your electrics work, then I'd suspect part of the main electrical circuit. It probably won't help, but I'd try running another earth from the engine block to the negative battery terminal with a jump lead.
