Dnk Posted April 7, 2010 Share Posted April 7, 2010 That's it though mate......funds. It's 1k to get the turbos done. I've been saving for ICE stuff for months, but the money is now going on getting the tubos done. I've had the car for nearly a year with no stereo, it's a good job the 2jz is a nice sounding engine. Thats a cheap re build on the turbos, i was quoted getting on for £1500 when i last enquired. Surely you could pop a cheapy in there for £50 Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted April 7, 2010 Author Share Posted April 7, 2010 Thats a cheap re build on the turbos, i was quoted getting on for £1500 when i last enquired. Surely you could pop a cheapy in there for £50 You have to shop around a bit, CR turbos are tried and tested with several members having had their turbos worked on by them with good results. It's £600 for the overhall, with the rest being labour. As for the stereo, I don't use the car daily so no stereo is not really an issue Quote Link to comment Share on other sites More sharing options...
TLicense Posted April 7, 2010 Share Posted April 7, 2010 It could be worse.... I'm having a similar symptom, and my turbo's are £1800 each. Quote Link to comment Share on other sites More sharing options...
Abz Posted April 7, 2010 Share Posted April 7, 2010 I am also seeing similar symptom's but I also get smoke on start! I hope both the value stems & turbo's are not going Quote Link to comment Share on other sites More sharing options...
JamieP Posted April 7, 2010 Share Posted April 7, 2010 It could be worse.... I'm having a similar symptom, and my turbo's are £1800 each. Fook me:( i really want to see your car pound out some huge numbers, i have faith in your setup. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 14, 2010 Share Posted April 14, 2010 mines doing this again , bloody cars Quote Link to comment Share on other sites More sharing options...
jaymdee Posted May 10, 2010 Share Posted May 10, 2010 mine too Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 10, 2010 Author Share Posted May 10, 2010 My turbos are being fitted back onto the car now. Ill update with the result when finished Quote Link to comment Share on other sites More sharing options...
Abz Posted May 10, 2010 Share Posted May 10, 2010 Mine 3... I think Andrew said he saw some smoke on boost Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 17, 2010 Author Share Posted May 17, 2010 Ok, mine has been cured with refurbed turbos, all is smokeless again in the world of Pistonbroke...............good times Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 17, 2010 Share Posted May 17, 2010 Nice one mate:) Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 17, 2010 Share Posted May 17, 2010 mine has cured itself? hasent done it for a while now , but im sure it will at the worst possible time Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 17, 2010 Author Share Posted May 17, 2010 mine has cured itself? hasent done it for a while now , but im sure it will at the worst possible time Mine was random puffs mate, where it wouldn't do it for days, then gradually, it got more consistant. Quote Link to comment Share on other sites More sharing options...
jaymdee Posted May 22, 2010 Share Posted May 22, 2010 Ok, mine has been cured with refurbed turbos, all is smokeless again in the world of Pistonbroke...............good times Hi mate can you PM me details please? eg, are they CR Turbos, how much & did you do the work yourself, if so how hard/easy, or get a garage to do it? cheers Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 22, 2010 Author Share Posted May 22, 2010 CR turbos did the work on refurbing them. Total cost for new seals, shafts, uprated internals with new impellers and new actuators £839. Supraturboschris removed and refitted them for me, but having spoken to Paul whiffen about doing the work, you're looking at £500 labour to remove and refit. The easiest way of doing it if you haven't got a trusted indy garage local to you who knows supras, is to probably get Paul Whiffen to do the lot. He can supply stage 1 refurbed hybrids fitted for about £1500. A little more money, but you get it all done under one roof. I managed to save a little money by utilising supraturbochris's skills with a spanner. Quote Link to comment Share on other sites More sharing options...
jaymdee Posted May 23, 2010 Share Posted May 23, 2010 cheers mate. will need to save a bit more dosh. Looked at Tony Licence's guide on here and not sure it's something I can do myself Quote Link to comment Share on other sites More sharing options...
