little bit of blue smoke
pistonbroke
Noticed today that my car belched out a puff of blue smoke after a while sat idling in traffic. I then managed to get it to do it again by coasting in gear off throttle (over run) and then applying the throttle again. I've never seen any puffs on startup which I thought would indictate stem seals, and I get no smoke on boost or at any other times.
So, according to this thread it could still be valve stem seals
http://www.mkivsupra.net/vbb/showthread.php?t=67516
But I get nothing on startup.
Throughout my searching, I've found that the PCV can cause smoking issues, but haven't found in what circumstances it would smoke.
Thoughts please, before I give the car to AFR for stem seal replacement.
Edit to add, my car has been sat recently for up to a month between starts, could this period have dried the stem seals out through lack of use?
White smoke is water, it's defo blue though and stinks of oil.
I've just been out to check the PCV valve, it's got blue oil mist all around it and the connecting pipe is solid, so no doubt the connecting breather pipes between the covers are the same too.
I'll change the PCV first seeing as it's dirt cheap along with the pipes and see if that has any effect. I'll report back once it's done with the results.
Feel free to suggest anything else in the mean time though :thumbs:
My valve stem seals are shot on my car but i only get smoke on start up and ive not seen it when backing off or on idle but ive read on here also that when backing off etc it could be turbo seals but dont quote me on that!!:)
Turbo seals would smoke on boost, but I get nothing, just on overrun. I finished work late last night and took her for a spirited drive, (the first one since I;ve had her back). My word she flys !! :D. It was too dark to discern whether I had any smoke but another run out today will confirm it.
See, mine doesn't actually smoke on over run, it's when the throttle is applied after over run, I get a little puff very randomley.
However, to report back after my blat last night, I got no smoke at all today while driving. Could it be some old oil deposits of oil that dried up while the car was stationary for so long?
mine was doing the same thing a while back , smoking on over run , , wouldt smoke on boost or start up , but then if i was driving around then stoped at lights or traffic it would begin to smoke ,
turned out a new tubby was in order:(, check your ic pipes for oil , ther should be a fine residue of oil anyway but if it lookms a bit exessive could be you turbo.
Dude,
I was getting a little puff on startup and also after coasting and blipping the throttle, having sat in traffic too though it smoked when throttle rapplied, so vaguely similar to your issues.
A good run down the bypass cleared it out for a day or so, then it returned. Did check IC pipes etc wondering if it was turbo oil seal.
Eventually went the whole hog for a head clean / stem seals at AFR, highly recommended.
http://mkivsupra.net/vbb/showthread.php?t=191906
In fact you replied to my thread! DOH!
Edited by caseys (see edit history)
Cheers Casey, I just got off the phone to John (dude) and chatted with him about it. I won't have the funds for a full head off recondition job until next year.
He's said though that stem seals would defo give me smoke on startup first thing, but I don't get any of that.
I've googled a bit for the past 30 mins and the PCV is a prime candidate for my symptoms. I'll wack a new one on seeing as thay are relatively cheap and report back with the findings.
I'll take off one of my FMIC pipes this weekend and have a gander. Fingers crossed the tubby seals aren't fubar'd. I can't afford to go single yet. (though if the missus gets wind of what I;ve been spending recently, I'll be single a lot sooner :D )
When i had my supe i went to local meet.
As we pulled up i blipped the throttle for someone asking to hear the zorst note.
When i did it filled car park up with smoke (blue/black) and after that it never done it ever again!
Oil level was perfect and so was everything else.
If its not pumping it out i'd wait till the mot and see what the emissions come out at.
  • 5 months later...
Just to resurrect this thread, the PCV valve has not worked, it's still randomly puffing out blue smoke once warmed up on pull away in traffic. I'm having the turbos taken off at the end of the month to have them reconditioned (hybridised :eyebrows: ) in the hope that it sorts the problem. I'll update this thread with the results.
My monies on stem seals, mine were absolutely shot but didn't smoke too much, when we got them off they were all rock hard and long overdue being changed
Do you not get any smoke on start up / mine did but only for a second or two
More caffiene required. Hope it's PCV for you chap as it'll be a lot cheaper a fix.
Just got a message back from michael, his problem was his turbos.
I think if i had the turbo seals going and was removing them for a rebuild then i'd be inclined to bite the bullet and do the head at the same time if funds allowed ofcourse.
That's it though mate......funds. It's 1k to get the turbos done. I've been saving for ICE stuff for months, but the money is now going on getting the tubos done. I've had the car for nearly a year with no stereo, it's a good job the 2jz is a nice sounding engine. :D
