Greddy electronic peak/hold/warning EGT and boost gauges
Adam W
Greddy electronic EGT and boost gauges with peak hold and warning. These come with the sensors, the cabling and the box of electronics. 60mm diameter, black faces with green illumination to match the standard Supra dashboard. They have a button you can press to make the display the peak value reached since you last reset it, and a red LED that flashes a warning when a user-adjustable level is reached. Full working order, these cost £130 each when new, you can have the pair for £100
All these parts are in North Herts, but can be posted if neccessary. Recorded post will be about £7 on these I think.
