Emanage
Steve
To be honest... you might as well get the ignition harness as well... it is not a lot of cash, I seem to rememeber around $40.... that way you have the flexibility for later....
The support tool is definitely a requirement to set it up...
I teamed mine up with the profec-e01 unit, purely because it integrates so well into the system and allows you to do minor tweaking without the laptop.
Gav
So whats the injector harness for?
Erm...to control the injectors??? *grin*
Sorry, in all seriousness, the emanage on its own fudges the airflow signal, the injector and ignition harness then can control the injectors and the sparks.
Gav
This would be the ideal package you'd want to get:
E-manage
Support Tool
Ignition Harness
Injector Harness
E-Manage Pressure Sensor
E-manage Pressure Sensor Harness
The support tool is the software and cable to connect to laptop, this is optional depending on who is doing the mapping. The pressure sensor/harness sends the e-manage the boost pressure.
