pc help
Dnk
Im trying to clear the drop down section of the address bar as theres just too many in it now, ive tried the
tools, internet options, delete browsing history route but nothing happens,
any ideas on how to clear it or do i need a history eraser download and if so is the one thats easy to use i can download.
Also i have a problem with java, ive checked its all enabled and java says its ok but when i go on youtube or autotrader it says ive got it switched off ?? again any ideas
cheers
dunk
I think its IE 8 and im using XP, ive tried just about every route it suggests on google search and the drop down address bar is the same.
Even after a restart.
I think my pc must have something daft going on as java is now working again, its begining to p me off though as it'll stop working say after watching 2 or 3 videos on youtube, and their not naughty ones either lol
If it's IE 8 you can manually delete them. Click the drop down and hover over one of them, you should see a red x on the right of the one your hovering over, clicking it will remove it.
not the best fix, but a fix all the same.
I think I'd download ie8 and reinstall it.
I dont get any red x's when i do that so i guess i possibly havent got IE 8 !!
I best go see what i have got lol
I just use google for searching, im not that hot on the pc so most of it if i get a problem is erm double dutch lol
How would i know if a search engine has become lodged into my IE ?
On my add/remove programs list i have IE 8 installed
number 1 is a third party search engine lodged in ie (nothing to be worried about)
number 2 is your internet explorers search engine.
If your list is in something like number 1 then you may have to go about a different way of clearing it..
but if its number 2.. then ill have to have a quick think about whats causing it to not be deleted :)
Its in number 2
try this:
IE8 > Tools > Internet Options > Content > AutoComplete Settings > Delete AutoComplete history > [select items to delete] > Delete
It looks like IE8 has a seperate "history" within the address bar as opposed to the actual history of browsed sites. By clearing the history you have cleared the browsed sites, but its still keeping a history of the main websites visited via typing them directly into the drop down address bar.. at least I think this is what it is..
Let me know if that works or not, if not im back to ze drawing boards!
You should be able to fiddle with autocompletes settings in order to make it not log history too.. but im not sure if setting a history log of "0" days means it will never clear it.. might be an idea setting it to "1" day so the most you will ever have is the current days auto-complete history in your address bar..
Failing that there must be an option to turn it off too :)
hmm..
On a plus note im having the same java problems as you but just switch over to mozilla for youtube..
If autocomplete didnt clear it then im confused, just did it on mine and it erased it all.. i even took a tick out of the box to say "use autocomplete for web pages" and its stopped logging them.
I cant imagine why any malicious software would attempt a death-by-address spam.. so it might be an idea (if it is getting to you that much) to reinstall the explorer - mines gone screwey a few times in the past and a fresh install of the explorer (usually) clears up any major problems.
ill keep looking though, stuff like this bugs me.
hmm..
Pc's bug no end as it never seems to do what it says on the tin lol
I take it to reinstall IE8 i'll need to remove it from my add/remove programs section then download it again ?
Found a website where lots of people having the same issue as you.. try this.. (if not tried already)
Click the Start button>Control Panel>System And Maintenance>Indexing Options, Click on Internet Explorer History, Click ADVANCED, Click RESTORE DEFAULTS.
Im not getting the indexing options part so not sure where thats differant.
Yes to remove it its from the add/remove part of control panel, could always go back to IE7 (I tried 8, im back on 7).
Try the restore defaults bit first though
I think as theres been lots of updates since IE 8 was installed i could be opening a can of worms removing it.
Not sure about that so think i'll have to get someone round to have a look before i crash my whole system.
Thanks for everyones help with this and if i get to the answer i'll post up and let you guys know.
its bugging me, seems your not the only one having that problem though.
If it were in vista seems to be corrupted history file of some sort but your in XP.. which has less "answers" available. Restoring it to its "just downloaded" state would be something id try to do, short of removing and reinstalling it at this moment.
If you have a tech-head friend just ask them to pop round for a bit and have a look at it, probably easier to fix if the system is in front of you..
Sorry the suggestions didnt work matey =(
