alex2jz Posted October 11, 2009 Share Posted October 11, 2009 (edited) Greets! Ever since i've got my NA Supra i've noticed that if you sit iddling and move the steering wheel left or right the rpm drops to an uncomfortable level than comes back to normal. I mean it hasn't been a big problem but i wonder if it's normal and if not what could be the cause. Thanks Edited October 11, 2009 by alex2jz (see edit history) Link to comment Share on other sites More sharing options...
Nic Posted October 11, 2009 Share Posted October 11, 2009 It's the power assisted steering pump which is putting load on the engine. If it's noisy and dropping the revs excessively, then could be time for a PAS oil change Link to comment Share on other sites More sharing options...
alex2jz Posted October 11, 2009 Author Share Posted October 11, 2009 Thanks Nic! Wanted to do a Power Steering Fluid change for a long time actually if this is what you meant. The steering is smooth and quiet only problem is a the rpm drop. Link to comment Share on other sites More sharing options...
Fitz Posted October 11, 2009 Share Posted October 11, 2009 It's the power assisted steering pump which is putting load on the engine. If it's noisy and dropping the revs excessively, then could be time for a PAS oil change Thanks Nic! Wanted to do a Power Steering Fluid change for a long time actually if this is what you meant. The steering is smooth and quiet only problem is a the rpm drop. Yup PAS = Power Assisted Steering Change the fluid mate Link to comment Share on other sites More sharing options...
alex2jz Posted October 11, 2009 Author Share Posted October 11, 2009 Thanks for the help guys! Link to comment Share on other sites More sharing options...
stevie_b Posted October 11, 2009 Share Posted October 11, 2009 Just as an aside, "dry steering" where you turn the steering wheel when the car's not moving puts a lot of strain on the steering system (of any car, not just a supra), and should be avoided if you can. Sometimes it's unavoidable of course. Link to comment Share on other sites More sharing options...
Andy Blyth Posted October 11, 2009 Share Posted October 11, 2009 Greets! Ever since i've got my NA Supra i've noticed that if you sit iddling and move the steering wheel left or right the rpm drops to an uncomfortable level than comes back to normal. I mean it hasn't been a big problem but i wonder if it's normal and if not what could be the cause. Thanks A part of the power steering system is a small valve that bleeds a small amount of air around the throttle when the power steering is being used. This should have the effect of slightly raising the engine speed if you're using the power steering with the engine at idle. If this is not happening, I would suspect a broken valve / blocked air tube. Link to comment Share on other sites More sharing options...
