single 1jz gte instal
Guest argy911
Guest argy911
fited this a few weeks ago to my soarer 1jz
insteaf spending £2500+ to convert it to maneul am thinking of buying a lexus is 200.
Des anyone know will my 1jz engine bolt straight on to the lexus bellhousing?
Guest argy911
Have you got any vids of it running? :) i'd like to see it in action :)
and why not fit an R154 box?? conversion should cost you under 1k and thats including a £600 brand new 1JZ bellhousing
no vids yet .have'nt yet fited ecu + had it maped..
only runing low boost at the mo.:(
Why go manuel??
Spend as little as £600 on the auto box (as long as it isnt already shagged) and it will handle the power. (As long as you are putting out less than 550 at the engine).
If you want to stay auto but have more power than that (looking at the single I would doubt it) or if the box is already shagged then get a rebuild kit from the states and get the box rebuilt for between £500 to £800, kit costing $800. Job done.
PS - Look in my garage and you will see I know a wee bit about modding Soarers...
The IS200 box won't bolt to the 1jz. It is a getrag box but different bell housings. The same box is used in the Honda s2000, nissan s15 etc so will handle power to a point but maybe not single 1jz power.
There are also many other issues with fitting the 1jz itself into the IS200.
As advised above the easier option would be to fit the R154 but then if we all picked the easy option then we would have a dull dull world lol.
The Aristo is the jap import version of the GS300 not the IS300. They are all auto's too.
The IS300 is available in the UK but only as an auto. The yanks got the manual version which uses I think the w58 box.
The only reason the diff should be of any concern is if you want a particular final drive ratio. certain diffs are interchangable but it is a bit of a minefield where diffs are concerned.
yea sorry , i meant the alteza not the aristo thats ths jap alternative to the is with better parts if im correct
The Altezza is the jap import of the IS200 but it has the same gearbox and diff although the box has a different bell housing again as the starter motor is on the opposite side.
The altezza has the 3s-ge 2.0litre 4pot engine that produces 210bhp. One of the best engines ever made I think. Other than that the IS200 and RS200 are very simliar with regards to spec.
