Guest alib Posted October 10, 2009 Share Posted October 10, 2009 Any tips for removing the bottom 'crank' pulley, in particular how undo the bolt and secure the pulley whilst doing so? Is the bolt Left Hand thread? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 10, 2009 Share Posted October 10, 2009 You need a crank pulley removal tool. There are two threaded holes, bolt into each, bar to support and a BIG breaker bar onto the bolt. Its torqued to about 300ft lbs from memory. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 10, 2009 Share Posted October 10, 2009 its a lot easyer with a pnumatic impact wrench Quote Link to comment Share on other sites More sharing options...
dcarrter21 Posted October 10, 2009 Share Posted October 10, 2009 yes but you will need an 1" drive one. i just made a tool up to hold it. then very long breaker bar. Quote Link to comment Share on other sites More sharing options...
Terminator Posted October 10, 2009 Share Posted October 10, 2009 (edited) Breaker bar and starter motor, been covered loads of times. Search and ye shall find. Edited October 10, 2009 by Terminator (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest argy911 Posted October 10, 2009 Share Posted October 10, 2009 Any tips for removing the bottom 'crank' pulley, in particular how undo the bolt and secure the pulley whilst doing so? Is the bolt Left Hand thread? Breaker bar on nut, crank engine once. Quote Link to comment Share on other sites More sharing options...
dandan Posted October 10, 2009 Share Posted October 10, 2009 Breaker bar and starter motor, been covered loads of times. Search and ye shall find. Breaker bar on nut, crank engine once. What do you fellas do about getting it done back up to the right torque? Quote Link to comment Share on other sites More sharing options...
Guest Luigi Posted October 10, 2009 Share Posted October 10, 2009 Use holding tool on the pulley and torque wrench on bolt. Pic shows a home made tool with two high tensile bolts into existing pulley threaded holes (x 2). Quote Link to comment Share on other sites More sharing options...
Rob Posted October 11, 2009 Share Posted October 11, 2009 Do you happen to know the thread / pitch of the holes in the pulley? Quote Link to comment Share on other sites More sharing options...
Guest Luigi Posted October 11, 2009 Share Posted October 11, 2009 OEM TT pulley: Two holes, 65mm centre to centre. I used 8mm high tensile bolts (M8 x 40), the heads have 8.8 stamped on them. I know very little about metric sizing, I just bought a small range of bolts until some fitted. They have a fine thread with a possible pitch of 1.0 The threads in the pulley holes will be clogged and may need cleaning first. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 11, 2009 Share Posted October 11, 2009 M8 x 1.25 pitch. I'd use cap heads myself. Quote Link to comment Share on other sites More sharing options...
Rob Posted October 11, 2009 Share Posted October 11, 2009 Many thanks Quote Link to comment Share on other sites More sharing options...
Guest alib Posted October 12, 2009 Share Posted October 12, 2009 bih help thanks lads, i take it the thread is standard rh thread. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 12, 2009 Share Posted October 12, 2009 Yes. Quote Link to comment Share on other sites More sharing options...
