DAVE-W- Posted October 10, 2009 Share Posted October 10, 2009 Is there much benefit in fitting uk cams injectors to a jspec or is it a waste if time. Is it a simple swap Cheers Dave Quote Link to comment Share on other sites More sharing options...
Guigsy Posted October 10, 2009 Share Posted October 10, 2009 depends on what you want. a bit more power put of bpu. then yeah. but you wont get many gains. Not 100% but would you have to run a uk ecu aswell? Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted October 10, 2009 Share Posted October 10, 2009 and uk fuel pump? Quote Link to comment Share on other sites More sharing options...
Nic Posted October 10, 2009 Share Posted October 10, 2009 Is there much benefit in fitting uk cams injectors to a jspec or is it a waste if time. Is it a simple swap Waste of time on stock turbos, the stock J-spec injectors supply enough fuel for BPU levels. If you were to fit UK injectors you would need some way of controlling the fueling, you would also need a resistor pack as the UK injectors are low impedance. The exhaust cam is the same on the UK and J-spec, the inlet cam on the UK spec is slightly longer duration (J-spec 224°/UK spec 233°), but I doubt you'd notice much of a difference. Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted October 10, 2009 Share Posted October 10, 2009 nic you are so knowledgeable! good to have you back and on the mend! Quote Link to comment Share on other sites More sharing options...
Nic Posted October 10, 2009 Share Posted October 10, 2009 and uk fuel pump? If the car is still running the factory fitted J-spec pump, it would be a good safety measure fitting a brand new UK pump. They are expensive though to buy new and they also fit in the hanger differently, so they are not a straight swap. Quote Link to comment Share on other sites More sharing options...
DAVE-W- Posted October 10, 2009 Author Share Posted October 10, 2009 In the words of Nic "Waste of time on stock turbos". Thats the to the point response i wanted. Cheers people Dave Quote Link to comment Share on other sites More sharing options...
